300 idles down to a stall - Polaris ATV Forum
post #1 of 17 (permalink) Old 06-05-2013, 07:22 PM Thread Starter
pedersdj's Avatar
I have a 95 300 4x4 trailboss. cleaned the carb repeatedly, and starts up good cold and sometimes starts when its warm, if it doesn't stall. I changed the lines on the carb. how long does the breather line need to be? Ill run it pinned for 30 seconds then coast down to a stop and the idle gets really low. ive had to turn the idle jet in to get it to keep running.
pedersdj is offline
post #2 of 17 (permalink) Old 06-06-2013, 04:14 AM
RVS Performance's Avatar
Idle speed needs to be set with the engine at operating temp. There's no set number of turns. Turn it in a little and blip the throttle and repeat till it its set correctly.
RVS Performance is offline
post #3 of 17 (permalink) Old 06-06-2013, 02:15 PM Thread Starter
pedersdj's Avatar
I do that almost everytime i ride and it keeps doing the same thing. its not getting enough air or fuel. The idles set so high right now that it moves when its cold.
pedersdj is offline
post #4 of 17 (permalink) Old 06-06-2013, 02:22 PM Thread Starter
pedersdj's Avatar
I also have air bubbles in my fuel line. could that be the problem?
pedersdj is offline
post #5 of 17 (permalink) Old 06-06-2013, 03:08 PM
Xploder's Avatar
NOTORIOUS for CRACKED Intake....better look very close, you will blow the engine....like I did year ago.
Xploder is offline
post #6 of 17 (permalink) Old 06-06-2013, 03:14 PM
Yep. If it won't hold an idle check for cracked carb boot or other air leaks in the engine.
post #7 of 17 (permalink) Old 06-06-2013, 07:07 PM Thread Starter
pedersdj's Avatar
what do you mean by intake?
pedersdj is offline
post #8 of 17 (permalink) Old 06-06-2013, 08:06 PM Thread Starter
pedersdj's Avatar
is the motor supposed to vibrate at idle? it doesn't while im driving
pedersdj is offline
post #9 of 17 (permalink) Old 06-07-2013, 06:28 AM
By intake we are referring to the carb mounting boot. If they crack and leak air in the engine will run lab and can burn a hole in a piston. It will vibrate more than normal If not running right.
post #10 of 17 (permalink) Old 06-07-2013, 02:33 PM
gdhillon's Avatar
^ would that cause it to not start? I just cleaned my carb on my 300 and put a new oil line in, its getting spark, the carb is getting gas. I tried starting fluid in the spark plug hole still nothing
95 polaris xplorer 4x4 400 2 stroke
94 polaris 300 2x4 2 stroke
93 7.3 n/a f250
gdhillon is offline
300 idles down to a stall pedersdj Polaris Trail Boss 0 06-05-2013 07:13 PM
30 mph stall and a strange leak..... treyh007 ATV Repair and Maintenance 10 04-20-2013 09:34 AM
2012 850 XP EPS stutter and stall kurt1963 ATV Repair and Maintenance 3 09-10-2012 03:57 PM
does your sportsman 400 want to stall in reverse? chatas1 Polaris Sportsman 2 07-23-2012 01:56 PM
Scrambler 400 intermittent backfire and stall jakef ATV Repair and Maintenance 4 08-31-2011 02:22 PM
