I found a motor bottom for $190.00 on Ebay. This should do the trick. I can't believe when a front chain breaks it can cause this much damage. I had it in the shop last fall when I had a winch, tires and rims installed, and serviced, I asked them to look it over good and let me know if it needs anything else. Don't know what else I could have done to prevent this from happening. It just broke. Hope it never happens again. By the time I'm finished with the repair it should cost me around $700.00 with parts and labor.
