sportsman still slipping with new belt - Polaris ATV Forum
post #1 of 11 (permalink) Old 04-15-2010, 03:58 PM Thread Starter
markmandoo's Avatar
Put a new belt on (Dayco) but it still slips badly. Do I need a new clutch?
markmandoo is offline
post #2 of 11 (permalink) Old 04-15-2010, 07:27 PM
chopper89's Avatar
from what i have read you can adjust the belt tension try pm blueline he will know.
2014 850 XP EPS BROWNING EDITION
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP T7 BEADLOCK RIMS
ITP 27 XTR TIRES
RICOCHET A ARM GUARDS
________________________
chopper89 is offline
post #3 of 11 (permalink) Old 04-17-2010, 06:16 PM
450rracer22's Avatar
maybe the spring on your clutch is wearing out?
450rracer22 is offline
post #4 of 11 (permalink) Old 04-17-2010, 07:09 PM
what do you think the reason is? is the belt feel lose, or is it pretty tight on the clutches?
have you ran the quad in neutral with the clutch cover off to watch the primary to see how it acts?
do you know what clutch it might be slipping on?
blueline15 is offline
post #5 of 11 (permalink) Old 04-20-2010, 06:12 AM Thread Starter
markmandoo's Avatar
thanks for the replys, it is slipping on the primary drive clutch. The belt seems fairly tight on the clutches. I've ridden it around the yard with the cover off and witched it slip when I stopped and tried to go again on a moderate incline. The primary clutch does have a slight groove where the belt rides. My wife and I used to ride it together and I guess I was in high gear too much when I shouldn't have been.
post #6 of 11 (permalink) Old 09-12-2010, 06:23 PM
arson1977's Avatar
I had the same problem. I took it in and the drive clutch was worn bretty bas, they replaced the drive clutch and a new belt. It's still slipping, mainly in high if there is any load,i never had the problem before the clutch got replaced. I found out about the problems when i took it in for annual maintenance. Am i able to tighten the belt myself?
arson1977 is offline
post #7 of 11 (permalink) Old 09-12-2010, 06:38 PM
grooves are not good. that might be the issue. it needs to be perfectly smooth
post #8 of 11 (permalink) Old 09-12-2010, 06:40 PM
its not too hard, imi just havent done it myself so im not really able to walk you through it, but our mechanics could do it in about 30mins or so with mininmal tools. i believe its the secondary that slides forward or back
post #9 of 11 (permalink) Old 09-12-2010, 06:47 PM
arson1977's Avatar
the secondary was the one with the groves that got replaced. when i got it home, it wasn't long before i noticed at about 30 mph in high she would start to slip, but as the belt got warm it seemed to stick, i think it just needs to be tightened a little. Thanks for the info.
post #10 of 11 (permalink) Old 09-13-2010, 03:29 AM
cwlongshot's Avatar
Do a quick search on U TUBE. There are a number of good short videos on servicing the CVT clutches and changing out the belt.
MUCH better and any wordy explanation one could provide here.
2015 RZR 900 Trail BLK. Pearl
Lock N Ride roof
Lock N Ride 1/2 windshield
Lock N Ride rear box
LED lights front, top & rear
LOTS more coming...
cwlongshot is offline
00 Sportsman 325 slipping issues. rollinbigpower10 Polaris Sportsman 6 03-26-2010 07:28 AM
850XP Belt Slipping xltsks Polaris XP 10 03-18-2010 07:09 AM
trailblazer belt slipping maverick ATV Repair and Maintenance 4 01-19-2010 12:50 PM
belt slipping cpr210 ATV Repair and Maintenance 3 10-27-2009 09:49 AM
Polaris Sportsman 90 clutch/belt slipping? ccc2253 ATV Repair and Maintenance 3 09-27-2009 05:53 PM
