Question about Greaseless Ball Joints - Polaris ATV Forum
post #1 of 5 (permalink) Old 07-03-2013, 06:29 PM Thread Starter
hazmat's Avatar
I just replaced my original ball joints on my '04 Sportsman 500 4x4 with OEM greaseless ball joints. Can you (Should You) grease polaris "greaseless ball joints"? My strut arm has grease zerks to grease the original ball joints.
hazmat is offline
post #2 of 5 (permalink) Old 07-03-2013, 07:08 PM
Bruce! is offline
post #3 of 5 (permalink) Old 07-04-2013, 05:26 AM
Boburk's Avatar
The original ball joints have a hole in the bottom of them to allow grease to get from the zerk in the bearing carrier to the ball joint. I don't think the replacement ones have this hole....making it impossible for grease to get from the zerk to the ball joint. At least that is how my EPI greaseless ones are.
Sean
_____
2008 Sportsman 300
- Purchased in 2012 with 25 hours on it
- UNI air filter
- Polaris 1500 winch
2011 X2 550
- Purchased in 2012 with 58 hours on it
- Viper 3500 winch
- Front lock and ride storage box
- Bighorn 2s all around
2012 RZR 570
- Purchased Dec 2013
- Viper Elite 3500 winch.
- Cooter Brown top
- EMP rear window
- Totron 30" curved spot light bar
2006 X2 500 (sold)
- Purchased in 2011 with 250sh hours and 2500sh miles
- 26" Trilobite HD tires on 12" SS108 rims
- Cabela's (Warn RT) 2500 winch
- Front rack extender
- Front brush guard
Boburk is offline
post #4 of 5 (permalink) Old 07-04-2013, 02:28 PM Thread Starter
hazmat's Avatar
The ball joints are not completely solid on the back. There is a larger opening on the back side compared to the original. It looks very similar to the image I have attached.
Thanks for the help.
Name:	ball joint.jpg
hazmat is offline
post #5 of 5 (permalink) Old 07-04-2013, 03:44 PM
bp405's Avatar
So I have an 2011 800 and the OEM ball joints part #7061158 is open in the back and will accept grease even though it is a greaseless unit. I replaced the originals as I am in the middle of a suspension/steering rebuild. The ball joints were in working order but upon removal I found no grease and a lot of dirt in the original units. So I was contemplating adding a zerk so it would be greaseable but came to the conclusion that it was unsafe to do so in that manner. See when I did a search for the ball joint removal guys were removing the balljoint retaining plate and using pressure from grease via a grease gun to pop the unit out. I feel much safer knowing the ball joint is being held in the strut by pressure and the retaining plate and not just by the retaining plate in the event the ball joint happens to get over greased through the zerk. But I will grease the ball joint under the dust boot using a needle adapter on the end of my grease gun in the hopes that it greases the unit and displaces dirt and water. Almost fogot before I press the new ball joint in I will fill the space above the ball joint with grease.
2011 sportsman 800 efi
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
bp405 is offline
Ball Joints williamk Polaris XP 20 02-27-2014 01:11 PM
ball joints gat ATV General Discussion 1 02-18-2013 06:15 AM
850 Ball joints Wolverine ATV Repair and Maintenance 4 05-30-2012 02:06 PM
Keep an Eye on your ball joints!!!!! skizmo Polaris XP 21 04-25-2012 12:41 PM
New ball joints Question Gator Pit Polaris Sportsman 6 12-17-2010 06:16 PM
