Keep blowing 20 main and 20 Acc Fuses on 2012 Sportsman 500 - Polaris ATV Forum
post #1 of 7 (permalink) Old 07-06-2013, 02:50 AM Thread Starter
DooDooBurd808's Avatar
I was trying to install the wiring on a winch on my week old '12 sportsman 500 ho and it didnt go so well so disconnected everything and restarted and realize I have a whole other issue all together not concerning the winch. i wanted to make sure my twelve volt was working for my tire compressor.I kept blowing fuses with the winch wiring and after i gave up with the wire install I had taken the fuse out of the 20 acc to the 20 main when i took the quad out for a run yesterday because i didnt have another 20 fuse. so i was running fuses in only 3 out of the 4 slots. the 12v didnt work i assume because there wasnt a fuse in the 20 acc slot. then finally just now i went to the store and got more 20 fuses and put one in the 20 acc slot thinking that the 12v would work now. Instead the 20 main fuse made a snap sound and blew out as i tried to turn the ignition on and no power to the quad. nothing from the winch is hooked up i disconnected everything. Everything is back to how it was before i installed the winch what could i have done? When i take out the 20acc fuse and put it in the 20 main and the quad starts up but the 12 v wont work. i tried to put in a new 20 fuse into the acc fuse slot while the thing was running (stupid i know ) and the thing started sparking and crackling. too much power through the 20 acc slot? i dont what could be the issue i have all the wiring back to how it was when i got it stock before the winch install and there is nothing obvious like wires touching metal/ negatives connected to positives etc. any thoughts? where im at there is no dealer so its not like i can take it in and have them diagnose it. : ( PLease help
DooDooBurd808 is offline
post #2 of 7 (permalink) Old 07-06-2013, 04:31 AM
Put in a 30 amp...lol
Bruce! is offline
post #3 of 7 (permalink) Old 07-06-2013, 05:20 AM
mscldawg's Avatar
The drive fuse sends power to the winch and the ADC/AWD COIL. THE acc fuse sends power to the pod acc and bulk acc . They both are powered by the chassis relay when the ignation is turned on. If your were getting arking when acc fuse was inserted then the chassis relay was jumping in and out due too a short in the acc circuit too ground and possibly damaged . So your acc line is shorted too ground somewhere. and the chassis relay is possibly damaged
Sent from my SCH-I545 using Tapatalk 4 Beta
12 sportsman 850XP EPS : So far its stock
mscldawg is offline
post #4 of 7 (permalink) Old 07-06-2013, 06:13 AM
lost cause's Avatar
sounds like you have a short somewhere. You need to go back through your wires and make sure everything is connected properly. Also ensure that there is not a cut in the wire and causing it to short out to the frame.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N AIR FILTER
POLARIS 3500 WINCH
POLARIS OEM BELT
STOCK EXHAUST
lost cause is offline
post #5 of 7 (permalink) Old 07-06-2013, 05:13 PM Thread Starter
anyone have a link to a diagram of how the acc circuit should look or something like that? where would it run from. assuming around the top headlight?
post #6 of 7 (permalink) Old 07-14-2013, 01:12 PM
calltrex's Avatar
Where u guys mounting these relays?
Got pics?
2013 Sportsman 500
calltrex is offline
post #7 of 7 (permalink) Old 07-14-2013, 02:02 PM
500sportsman's Avatar
Make sure your accessory socket is hooked up correctly 12v to centre and ground to the outside terminal.
05 SPORTSMAN 500 HO
Polaris hand guards
Polaris front and rear bars
Polaris rear rack extender
Rear LED reverse light
Front 16 inch LED light bar
3 headlight mod
500sportsman is offline
Main fuse keeps blowing on my Sportsman rob_in_mn ATV Repair and Maintenance 3 05-21-2013 03:13 PM
blowing fuses on 2007 sportsman 800 eaglefreddie Polaris Sportsman 4 01-20-2013 12:24 PM
HELP! sons sportsman 90 blowing fuses? ohchiiit Polaris Sportsman 2 06-28-2012 01:59 PM
2008 SPORTSMAN 500 EFI X2 (blowing 20amp fuses) DGAUSE ATV Repair and Maintenance 2 12-31-2011 05:19 AM
Winch keeps blowing fuses SilverSS427 ATV Repair and Maintenance 2 12-22-2011 05:38 PM
