1997 Xplorer 400L - Polaris ATV Forum
post #1 of 6 (permalink) Old 08-05-2013, 05:42 PM Thread Starter
fastpitch1's Avatar
1997 Xplorer 400L
I'm new to the site. Recently bought a 97 Xplorer 400L that won't start with electric start but does with one pull every time. I have a good battery and believe the starter to be shot. What is the best way to get the starter off this beast and a new one back on it. Do I have to remove the clutch covers, the clutch, the driven clutch etc. Does the drive chain have to come off the sprockets and the recoil starter removed? Any help on these questions would be a great help.
Also had brake caliper issues and am still looking for the rear caliper replacement. Also, is it possible to replace the piston on a front caliper?
fastpitch1 is offline
post #2 of 6 (permalink) Old 08-05-2013, 05:47 PM
Bruce! is offline
post #3 of 6 (permalink) Old 08-05-2013, 07:39 PM Thread Starter
fastpitch1's Avatar
Thanks for the welcome. I hope I get a reply to my query.
post #4 of 6 (permalink) Old 08-06-2013, 01:58 PM Thread Starter
fastpitch1's Avatar
I worked on the Xplorer all day. I think I did more than I needed to but before I got too carried away I backed up.
I took the clutch guard cover off and of course had to take the foot rest off before I could get the guard off. Before I got carried away and took the clutch, driven clutch etc. off I went to Plan B.
I hooked up my chain hoist to a 4x6 that I placed across the trusses in my 36x50 foot garage. I hooked the hoist to the front of the machine and raised it right up off the floor so only the rear tires were touching the floor. That way I could see the starter and the three nuts that had to come off. I rapped on the starter pretty hard thereafter and got it to release from the engine. However, I can't get the starter out as the bendix is in the way. I can't get the bendix out past the flywheel as there is not room.
My issue now is: how do I remove the flywheel as that nut is pretty darn tight and I have a breakage fear.
Anyone help me out?
Bob
post #5 of 6 (permalink) Old 08-06-2013, 03:05 PM
Diesel man 03's Avatar
Did you take the bolt out from the flywheel side that holds the starter in, I use to have a 99 and if I remember there is one long bolt that holds it in.
Diesel man 03 is offline
post #6 of 6 (permalink) Old 08-06-2013, 07:09 PM Thread Starter
fastpitch1's Avatar
On the '97 Xplorer there are two bolts inside the flywheel housing area. I took both of those out, removed the nut holding the battery cable to the starter and managed to get the two bolts out that hold the starter to the engine. The bracket remains on the starter. I can't get the darn thing to clear the bendix though and I can't get the bendix to clear the flywheel on the recoil starter side.
1997 xpress 400L wont start, help!!!! 96xpress400 ATV Repair and Maintenance 38 07-08-2012 11:27 AM
Need help with cylinder head water tube on a 1997 Sport 400l. chas400sport ATV Repair and Maintenance 2 06-06-2012 09:40 PM
1997 Sportsman 400L Solenoid Question hsdtech Polaris Sportsman 4 12-10-2010 07:02 PM
1997 400L Idle's won't Take any Throttle!!! ddbudd ATV Repair and Maintenance 4 11-23-2010 04:20 AM
1997 sportsman 400L Overheating cmb1503 ATV Repair and Maintenance 1 09-27-2009 01:37 PM
