Old 04-26-2010, 08:03 AM
jonj's Avatar
Member #3946
Squeaky Steering
My steering wheel squeaks when I turn it, any suggestions?
Old 04-26-2010, 08:06 AM
Tumbleweed's Avatar
Member #3583
Assuming you have a RZR or regular Ranger (steering wheel).
I would grease the steering stem bushing to start with.
Jerry
2010 Red 850 "T" & '08 700 Camo Grizzly w/ EPS & '07 700 Camo Grizzly w/ EPS
Old 04-26-2010, 09:53 AM
jonj's Avatar
Member #3946
It is a '06 sportsman 500
Old 04-26-2010, 05:15 PM
4getful2's Avatar
Member #1234
it's usually the top bushing that needs lubed.you may have to take off the hood or the lower half of the headlight plastic to get to it.
atv squeaky and stiff steering
how do you change steering wheel on ploaris ranger
how to change bushings on steering column of polaris ranger
how to change de steering post from atv
how to change steering wheel on polaris razr
polaris ranger steering problems
polaris ranger steers hard
polaris rzr loose steering fix
polaris rzr squeak
polaris rzr steering bushing
polaris sportsman steering fix
polaris sportsman steering squeak
polaris sportsman steering squeak 500
shock sprng skeaks when turning the steering on polaris ranger
squeaky steering polaris sportsman 500
squeky steering polaris sportsman
steering bushing squeaking on atv
sterring problem on 2009 polaris ranger
troubleshooting my polaris ranger steering
what causes squeaky sterring on polaris razor
tight steering sportsman500 Polaris Sportsman 5 03-27-2011 01:37 PM
trouble with steering l-rod Polaris Sportsman 11 11-09-2010 04:35 PM
Steering problem Tank3277 Polaris Sportsman 16 06-13-2010 06:16 AM
2009 sportsman 850 squeaky bushings craigracin15 Polaris Sportsman 13 04-20-2010 03:01 AM
Steering Problem jbragg87 Polaris Sportsman 8 02-28-2010 12:07 PM
