2002 Sportsman 700 Twin "No Spark" - Polaris ATV Forum
post #1 of 4 (permalink) Old 04-26-2010, 07:20 PM Thread Starter
tarzy's Avatar
Hello, I'm not sure if I have posted here before, but I'm in need of any ideas about what I've discovered with this ATV......... It has a Ducati Alternator-driven CDI/Coil Ignition system. I have taken the steps of testing to this point: The manual says 34VDC for the Exciter Coil; I measure 20VDC. The Pulse/Trigger Coil measures correctly. I have tested the ETC switch, which is good adjustment-wise, and although this Exciter component value is out of spec, it's my inclination that this is still a dead CDI. I should mention I work in a small shop, and have vast experience with many vehicles, especially racing, but as we all know every day brings a new challenge. This is a big one, considering I had to wait 2 weeks for my peak reading adapter before I could start my tests. BTW, I am a Polaris owner too!
Regards, Tarzy
tarzy is offline
post #2 of 4 (permalink) Old 04-27-2010, 01:54 PM
tackwest1's Avatar
Tarzey,
Unfortunately the 02 700 has a history of bad stators. I'm not sure what exactly goes bad, but I have seen several that had to be replaced. I would also check the continuity from the pickup. I had a stick pull the wires and broke them inside the insulator. Took a while to find. I think the Ducati ignition was the suspect one. I will try and get the specs on friday.
tackwest1 is offline
post #3 of 4 (permalink) Old 04-27-2010, 10:05 PM Thread Starter
tarzy's Avatar
Thank you too!
Originally Posted by tackwest1 View Post
Tarzey,
I got some advice to use this update (ignition replacement kit update #2202602) from Polaris but I found one on eBay. Thank you again for your input; I was suspect of the CDI/Coil from the beginning. Oops! Before I forget, if you have the Ducati CDI/coil Alternator driven system, the exciter output is 34VDC, and the Trigger/Pulse coil output is 3.3VDC, and you must either use a DVA (direct voltage adapter) or else an already "peak-reading" Multimeter such as one of the Flukes, as you are capturing a "peak", which is their standard for testing. The unit I'm working on had the trigger output, but only 18-20VDC from the Exciter coil. Some even call this system a "Magneto", such as the Polaris Service Manual.
Best of luck, Tarzy
tarzy is offline
post #4 of 4 (permalink) Old 09-19-2011, 04:02 PM
beastrider9's Avatar
I have the same problem but havent gone into the side cover yet. I'm not a mechanic per say, but I do alot of fixes myself. Mine has no vdc on any of those wires leading into the exciter while cranking as shown in the manual. the only voltage I get is on the wire from the ignition about 7-8 vdc. the manual is not clear if I test the brown/yellow and red/black together, or to ground but I did both and still got nothing. I'm suspecting I need to go into the side cover and find the coil to test it now right? Again the manual is not clear on this. I'm getting from you guys that the stator and coil are maybe one unit? Any help is appreciated. If anyone wants to call and walk me through that I'm good with that too. This is the girlfriends pit bike at the offroad races so I kinda need it done quick. Thanks.
beastrider9 is offline
Want to "wake" up your 300 Hawkeye/Sportsman? Firehawk ATV Performance Modifications 10 01-21-2014 07:01 PM
2006 Sportsman 700 EFI "dies above idle" NEED HELP ASAP FOR WEEKEND RIDE xlwater Polaris Sportsman 6 12-29-2012 10:59 PM
2004 sportsman 500 ho questions/concerns "newbiee" nicks500HO ATV Repair and Maintenance 11 05-26-2011 02:49 PM
Sportsman 400 Don't Shut Off "sometimes" polarisjunk Polaris Sportsman 5 01-01-2011 07:32 PM
95 700 Sportsman intermittent pod failure "HELP" bigtodd ATV Repair and Maintenance 3 02-21-2010 06:35 AM
