Old 06-05-2009, 06:45 PM
Larry75's Avatar
Member #616
2000 Xpedition 425 Carb Problem HELP PLEASE
Help. The Carb on my Xpediton was leaking, so I replaced the bowl gasket and while I the bowl was off I replaced the needle and seat as the seal around the needle had dryed up. After I got it back together It ran fine for several days. Today the motor starts and idles with the choke on, but the moment I press the throttle the engine dies. The air box is clean and not blocked, gas is fresh, plug is clean...
Where do I start??
Old 06-05-2009, 08:44 PM
Old 06-09-2009, 07:17 AM
Dirty Dawg Dale's Avatar
Member #552
When you replaced the needle valve did you clean the carb? I would remove the carb, then drain the fuel from the carb in to a clear container looking for any dirt. Then I would place a clean rag on the bench and disassemble the carb and make sure you remove all jets. Inspect all jets to make sure they are free of any dirt. Chances are there still might be some dirt in the carb, sounds like the pilot jet might be plugged. I would also install a new fuel filter. Good Luck!
2000 polaris 425 expedition carb
2000 polaris 425 xpedition how to take carb off
2000 polaris expedition 425 carberators
2000 polaris xpedition 425 carb is leaking
2000 polaris xpedition 425 carburetor rebuild kit
2000 polaris xpedition carburetor
425 expedition carberator
carb removal polaris expedition 425
carberator rebuild kit for xpedition 425
carburetor 2000 polaris 425 expedition
carburetor repbuild kit 425 xepedition
polaris 425 expedition leaking
polaris 425 xpedition carburator
polaris carburetor rebuild kit xpedition 425
polaris xpedition 425 2000 repair
polaris xpedition 425 carb rebuild kit
polaris xpedition 425 dies when moving
polaris xpedition dies when given gas
what to remove to get carb off 2000 polaris 425 xpedition
