Old 06-06-2009, 02:48 PM
edwaj1's Avatar
Member #623
Unhappy 1985 trail boss 250 question
Hello all,
I've been reading here for awhile, but now need the collectives help!
I've tried searching for my problem, but have not found anything definitive.
I recently acquired the aforementioned 1985 trail boss 250, rebuilt the carb, replaced the crank seals, set the timing to the specified 23.5 btdc and also tried everything from 21-27 degrees as well.
Problem is, this runs like a scalded ape UP to 1/2 throttle, (appears to max out in rpm) anything over 1/2 throttle and it completely bogs out.
What am I missing here?
Thanks in advance!!
Old 06-06-2009, 03:55 PM
Old 06-07-2009, 02:40 AM
edwaj1's Avatar
Member #623
is there any way to test the c.d.i. for proper spark advance?
Old 06-09-2009, 07:02 AM
Dirty Dawg Dale's Avatar
Member #552
This is a loaded question but here are some things that might help you out. Sounds like a needle valve going bad or possible wrong main jet also check the needle position. One other thing it could have the wrong clutching. [There is no way to test the cdi.]
1985 polaris 250 tail boss
1985 polaris 250 trail boss
1985 polaris 250 trail boss repair manual
1985 polaris trail boss
1985 polaris trail boss 250
1985 polaris trail boss 250 pics
1985 polaris trail boss atv pics
1985 polaris trail boss carburetor adjustment
1985 polaris trail boss free manual
1985 polaris trailboss
1985 trail boss 250
1985 trail boss 250 pictures
how to adjust timing on a 1985 polaris 250 trail boss
how to fix the timing on polaris trail boss 250
image polaris 250 1985
polaris 1985 250 trail boss timing
polaris 250 1985 atv pictures
polaris trail boss 250 timing
trail boss 1985
what do you set carb on a 1985 trailboss
