Old 05-10-2010, 05:40 AM
itchee1's Avatar
Member #4818
Hawkeye 300
Have an 2006 Hawkeye 300 4x4. When I turn on the AWB button, it blows the main fuse. Where do i start? is the a schematic online to follow?
Also, both rear tires do not spin when driving. is this normal?
Itchee1
Thanks in advance for all help
Old 05-10-2010, 09:00 AM
itchee1's Avatar
Member #4818
CV joint
Tore into the bike today. Right rear cv shaft is in 3 different pieces. needs new CV obviously.
About the awd shorting out. when I unplug the wires going into the front "differential", the shorting stops. what is in there that will cause shorting? Is is a eectric clutch, or could it just be wires wet?
cannot take it apart at this time, because i don't have the appropriate torx bit.
thanks itchee
07 polaris hawkeye wire diagram
2006 300 hawkeye ignition fuse location
2006 polaris hawkeye cdi wiring
2006 polaris hawkeye fuse location
2006 polaris hawkeye wiring
4x4 fuse box 2006 polaris hawkeye
hawkeye 300 blowing fuses
polaris 300 4x4 fuse location
polaris 300 fuse location
polaris hawkeye 300 hard to start after a few weeks
polaris hawkeye 300 wiring
polaris hawkeye 300polaris hawkeye 300polaris hawkeye 300
polaris hawkeye front differetial
polaris hawkeye keeps blowing fuses
where are fuses polaris hawkeye
where are the fuses on a hawkeye 300?
where is fuse on polaris hawkeye
where is the fuse box on a hawkeye 300
where is the fuse polaris hawkeye 300 06
where is the fuses on polaris hawkeye
Hawkeye Problem fishbone ATV Repair and Maintenance 5 08-09-2010 02:32 PM
06 hawkeye information crackenzag ATV Repair and Maintenance 3 12-28-2009 08:41 AM
300 Hawkeye or 330 Magnum or? AZDesertRat ATV Purchasing and Price 11 11-21-2009 07:15 PM
300 sportsman/hawkeye canaan canam Polaris Sportsman 5 11-05-2009 06:53 AM
06 Hawkeye float yanks2362 ATV Repair and Maintenance 0 09-06-2009 04:06 PM
