Oil/Gas Ratio - Bypassing Injection System - Polaris ATV Forum
Old 05-11-2010, 03:46 PM
Observer's Avatar
Member #2737
Question Oil/Gas Ratio - Bypassing Injection System
I'm rebuilding a 1989 Polaris Trail Boss 4x4 250 2-stroker and decided to plug the oil injection system ... going to use a fuel/oil mixture instead.
While down at our local Polaris dealer for some parts, I asked the service manager if he knew what the oil to fuel ratio was for this machine. After much referencing he was unable to tell me ... just thought maybe it was 32:1. After all my work, I'm not ready to chance it ... DOES ANYONE HERE KNOW FOR SURE?
Sure would appreciate a definitive answer.
Thanks guys!
John
1989 Polaris 250 Trail Boss 4x4
All Stock
WE ARE EVERYWHERE ... III
Old 05-11-2010, 04:19 PM
The Kid's Avatar
Member #3743
we run them at 52:1
The Kid
heel clicker
Warn 2500 puller outter
SS108's
29.5's Laws skinny/fat
rubber down custom intake
homemade exhaust snorkel
rad. relocated up top
chains on front & rear A arms
swaybar removed
Old 05-12-2010, 08:59 PM
Observer's Avatar
Member #2737
Thanks 'The Kid', but that sounds a little to low ... so I asked the engine guy on this forum - TinkerMan - and he gave me the following ratios:
32:1 - Break-In Ratio
40:1 - Normal Engine Ratio
Thanks TinkerMan!
All Stock
Old 05-14-2010, 09:31 AM
1of7627's Avatar
Member #4155
Doesn't the oil injection system do more than just add oil to the fuel? I thought it supplied oil to the crank and rod bearings as well (at least on the water cooled 350's and 400's).
Old 10-15-2011, 03:45 PM
poop's Avatar
Member #17131
Anyone know if you can just run premix or will it hurt anything else?
2003 Sportsman 400
1990 indy 650 fuel premix
1992 polaris trail boss 350l 4x4 gas mixture
1993 polaris 250 4x4 fuel mixture
1994 polaris trail boss 300
95 polaris trail boss fuel mix ratio
fuel mixture for a 97 polaris xplorer
gas to oil ratio for polaris 2 stroke
how do i change polaris boss 250 to gas/oil mix
polaris 1994 400 sportsman fuel to oil ratio
polaris xpress 300 by pass oil mixture
proper oil gas mixture 94 polaris 300 4x4
what is the gas oil mixture for a 1992 polaris 250 trailboss
oil injection pump frony83 ATV Repair and Maintenance 4 05-19-2015 10:37 AM
Taking off oil injection going to premix kbhd6180 ATV Repair and Maintenance 16 06-04-2013 03:15 PM
97 Xpress 300 - What is the correct gas/oil ratio? Nandy Polaris Sportsman 8 09-07-2010 12:47 PM
06 800 gear ratio? somdsp800 Polaris Sportsman 3 04-29-2010 06:46 PM
how to belled/check oil injection bigopie1 ATV Repair and Maintenance 5 10-28-2009 03:37 PM
