Old 05-20-2010, 06:41 AM
tt425's Avatar
Member #3687
how do you test a cdi and coil?
I have a 1995 Polaris 425 4x4 Magnum no spark. New stator ohms are correct on stator. Need some help on testing the coil and cdi. Can anyone help me?
Old 05-22-2010, 04:28 PM
Lawn Motorsports's Avatar
Member #5030
You cannot test the CDI. You can check the coil though. Use an ohmmeter to check continuity between the coil ground as well as the ignition wire. Resistance should be around 3 Ohms. You know if the CDI is bad by process of elimination.
Old 05-26-2010, 10:45 AM
tt425's Avatar
Member #3687
testing coil/cdi
Thank You
cdi atv testing
checking cdi ignition coil
how to check polaris cdi box
how to test a polaris cdi box
how to test an atv cdi
how to test cdi on atv
how to test polaris cdi
how to test polaris cdi box
polaris cdi box test
polaris cdi box testing
polaris cdi test
polaris coil test
polaris sportsman cdi test
test a cdi box on atv
testing polaris cdi
2004 Sportsamn 400 stator test Kujo1967 ATV Repair and Maintenance 5 11-05-2012 12:44 AM
02-03 sportsman 700 cdi/coil blazed20s ATV Parts for Sale 5 06-29-2010 04:14 AM
Emissions test question....... oilcan Polaris Sportsman 2 05-10-2010 12:57 PM
Test ride with new Elka Elites installed HONDARACER ATV Brakes & Suspension 9 03-25-2010 07:42 PM
850 XP Test Drive gurtie ATV General Discussion 13 10-07-2009 09:44 PM
