Old 05-22-2010, 07:26 PM
bluedge8's Avatar
Member #5021
re installing fuel tank in '99 sportsman 500
Im trying to get the fuel tank back in the frame and it won't go
I dont even want to say how long I've tried to get it back in, I can get the lf tab seated but not the right front
anybody else ever have difficulty?
Old 05-24-2010, 04:36 PM
overdbars's Avatar
Member #4106
Good Evening my friend,
Make sure you are not installing the tank backwards. I know it sounds dumb but know someone who was trying to do just that. The large part of the tank goes in first. The tabs with holes in them should be near the center of the ATV while the tabs without holes will go to the front. I took the gas cap off & it slid in. On my first attempt I had the fuel lines routed over the frame & had to disconnect & reroute the two lines under the top of the frame.
What is it getting hung up on ???????
JD
Old 05-25-2010, 01:35 AM
bluedge8's Avatar
Member #5021
thanks for responding, turns out I had it apart for too long, 6 weeks and just completely forgot how it went together, so last night I finally figured out that the front tabs go UNDER the steering post bracket, not IN the bracket, and it popped right in. I was beginning to think the frame was really bent.
500 sportsman gas tank install
99 polaris sportsman 500 capasities
99 polaris sportsman 500 fuel tank
99 polaris sportsman main fuel line
fuel tank capacity of sportman 500
gas tanl install on polaris
how to fix fuel line on a polaris sportman 500
how to install atv gas tank
how to install polaris sportsman 500 fuel tank
how to install the gas tank on a polaris sportsman
installing a polaris sportsman gas tank
installing gas tank on atv
oem polaris sportsman gas tank install
polaris 400 gas tank size
polaris 500 fuel tank
polaris sportsman 500 gas tank capacity
power steering 99 sportsman
power steering kit for 99 sportsman
remove fuel tank sportsman 500
08 sportsman 6x6 plastic oil tank to old style aluminum tank duhibrokeit ATV Performance Modifications 4 03-02-2010 03:45 PM
Fuel Tank Foam Seal ???? Farmer Green Polaris Sportsman 7 01-25-2010 06:27 PM
Installing a power steering kit on a Sportsman sjcarp ATV General Discussion 2 11-11-2009 05:19 AM
foam on fuel tank R0CHMHL ATV General Discussion 1 09-16-2009 02:55 PM
Fuel Tank for 2005 and 2006 Sportsman 700 EFI asylum ATV Repair and Maintenance 0 06-02-2009 03:22 PM
