Old 05-28-2010, 01:59 PM
4chevys4me's Avatar
Member #4603
Need a quick fix
02 sportsman 500 HO. 1. What goes wrong with the speedo? Are they fixable? Crappy design to run everything through them. Bad Polaris Bad>>>I could care less about the speedo (nor would I wear one). What is the easiest way to bypass this system so My 4x4 works. I have Neutral light, speeedo back lit light, needle wont budge and I have the Reverse indicator light. Is this a sensor issue or speedo? Any help and specific instructions would be great. I have searched and there is just too many answers. I am a wounded MX guy making the switch to this 4x4 area and need some help. I have found this site to be most helpful. Thank you in advance..
Paul
Old 05-28-2010, 02:12 PM
PopeClaas2nd's Avatar
Member #5135
I think I saw you answer in "Instrument Cluster Problem 04 Sportsmen" thread, a couple of posts down about how somebody spliced wires underneath the speedo to bypass.
Old 05-28-2010, 04:15 PM
big4x4mudder's Avatar
Member #4725
I had this problem on my 01 sportsman on back of speedo there was a plug that had 6 wires I spliced into the 2nd wire in from each side of plug and ran them to a water proof switch now I have to flip 2 switches for 4wd no big deal a new speedo was over $300 so this is how I fixxed it hope this helps
Old 05-29-2010, 02:50 AM
4chevys4me's Avatar
Member #4603
Why two switches? Is there a way to bypass this and still use the stock switch?
Old 05-29-2010, 07:49 AM
Member #4725
yeah you could just splice the 2 wires togather I just felt better putting in a switch
fixing lights on polaris atv
polaris instrument cluster instructions
Need quick answer. disco ATV Repair and Maintenance 5 08-17-2010 05:42 PM
Seeking Help from Me?--Check here real quick blueline15 ATV Repair and Maintenance 7 05-01-2010 04:19 PM
Best prices ever on aftermarket Predator parts!!! Get them quick redneck2725 Polaris Predator 0 03-03-2010 02:26 PM
Quick fan fix for '04 Sportsman 500 HO Folks ATV Repair and Maintenance 1 02-23-2010 01:54 PM
quick fix on loose tierod ends clutchman ATV Repair and Maintenance 1 04-17-2009 10:19 PM
