Old 05-28-2010, 05:46 PM
pdb141's Avatar
Member #4973
oil change
I have an 04 scrambler 500 and was wondering when you change the oil is there two places you change it...i see where the bolt is on the oil tank,,,is there one under the quad too???? thanks
Old 05-28-2010, 10:34 PM
Razorback's Avatar
Member #4649
You can pull the plug in the crank case if you really want to. But you don't have to.
Drain the tank, then leave the plug out and the oil pan under it. With the ignition off, pull your recoil rope 10-12 times. It'll suck up the oil in the crankcase and it'll come out of the tank. Do that 3 or four times, waiting a couple minutes between each time for oil to settle in the crankcase. Then change the filter and fill er back up.
atv maintenance changing oil
atv oil change
atv polaris 600sportsman oil change
how to change oil in a polaris atv
how to change oil in polaris 600
how to change oil in polaris atv
how to change oil on a polaris atv
how to change the crank case oil on a polaris atv
oil change
polaras oil change
polarias atv oil change
polaris 600 fluid changes
polaris atv forum oil change
polaris atv oil
polaris atv oil change
polaris atv, oil change
polaris forum oil change
polaris oil change
polaris utv oil change problems
what kind of oil is needed in a polarias atv
boot change murthebear Polaris Sportsman 3 04-25-2010 04:57 PM
belt change maverick11 ATV Repair and Maintenance 2 04-15-2010 06:31 PM
Forum change? dodgeram3500 Site Issues & Suggestions 7 02-21-2010 09:20 AM
First oil change jazman Polaris Sportsman 2 02-07-2010 05:54 AM
Oil change walker45 ATV Repair and Maintenance 7 06-30-2009 06:53 PM
