CV joint bearings - Polaris ATV Forum
Old 05-30-2010, 06:36 AM
dclavell's Avatar
Member #5161
CV joint bearings
I am in the process of replacing the upper left CV boot and the bearings popped out. I cannot get them back in. Can anyone provide some insight?
tnx,
doug
Old 05-30-2010, 06:53 AM
dclavell's Avatar
Member #5161
More detail
I should have detailed my situation when I started the thread. We're talking left in-board CV joint on a 2008 Outlaw 525 IRS. Bearings in question are the in-board ball bearings and race that are located on the end of the shaft that goes into the rear-end where the chain is.
tnx,
doug
Old 05-30-2010, 08:29 AM
dclavell's Avatar
Member #5161
CV Joint bearings
What a dope addict!
The balls don't go INSIDE the race. They just kinda hang on the outside - once they're greased!
Does anyone disagree with this?
doug
2008 polaris outlaw irs cv joint bearing
atv cv bearings
cv joint bearing balls
how to take the bearing of the axle of a 525 outlaw irs
outlaw 525 cv replacement
outlaw 525 rear inner cv joint ball bearings
polaris atv cv joint bearings
polaris cv ball bearings
polaris cv bareing
polaris outlaw 525 irs cv joint
polaris outlaw cv inner bearing
polaris outlaw inner cv rebuild
Big money saver for Polaris Hub Bearings 450rracer22 ATV Repair and Maintenance 9 08-10-2012 07:51 AM
Polaris Sportsman 500 Wheel Bearings ipaman Polaris Sportsman 10 03-13-2011 01:07 AM
08 outlaw 450 front hub bearings 92lowtoy ATV Brakes & Suspension 2 06-01-2010 12:44 AM
05 sportsman front wheel bearings jmdpolarisman ATV Repair and Maintenance 6 02-20-2010 08:38 PM
Front Hub Bearings Currinjason@aol.com ATV Repair and Maintenance 1 03-25-2009 09:13 PM
