Old 06-06-2010, 11:45 AM
robertseber's Avatar
Member #5286
pouring oil out exhaust
i have about a 95 polaris 250 trail boss 4x4 and it pours two stroke oil out exhaust
im guessing that means somethings messed up in the carb correct i know nothing about a 2 stroke could i do a block off plate and just pre mix my gas first i heard something about the crank getting a little oil off the 2 stroke oil anyone know about that
Old 06-06-2010, 04:30 PM
Old 06-06-2010, 04:59 PM
Member #5286
DANG thought i had some help lol
anyways thanks bruce hope to get some useful knowledge here
Old 06-07-2010, 10:04 AM
thecableguy's Avatar
Member #5141
The crank is lubricated by the oil/gas mix. You shouldn't have oil "pouring" out the exhaust, but blue smoke and an oily residue is pretty normal.
I haven't switched mine to premix as it seems to be running fine, the auto-injection systems on these machines seems to be pretty bulletproof.
The Haynes manual I borrowed from our local library shows a test you can do to check if your oil pump is working correctly as well as a procedure for adjusting the oil pump cable.
Jim
______________________________
1992 Polaris Trail Boss 250 4x2
Old 06-09-2010, 07:31 AM
Member #5286
maybe ill have to give the library a try and see if i dont have the book i think im just gonna go to premix hope this carb is as easy to clean as my warrior
atv oil in exhaust
can i disconnect the oil pump and mix the gas on a 2 stroke trail boss
can oil come out of my atv exhaust
how to adjust oil pump for 1992 trail boss
oil coming out exhaust polaris trail boss 250
oil coming out of exhaust 2 stroke
oil coming out of exhaust on atv
polaris 2 stroke oil from exhaust
polaris 250 has oil coming from exhaust
polaris 250 oil from exhaust
polaris 250 trail boss. blowing oil out of exhaust
polaris atv muffler oil
polaris has oil out of exhaust
polaris oil in exhaust
polaris oil out of exhaust
850 exhaust FL8fitty ATV General Discussion 16 06-07-2011 01:43 PM
exhaust caizar Polaris Sportsman 2 11-20-2009 07:47 AM
800 exhaust gomer4877 ATV Performance Modifications 4 10-02-2009 05:41 AM
800 Exhaust S&MJames ATV Performance Modifications 4 07-03-2009 06:29 PM
Best Exhaust for 700? wildmanben ATV Performance Modifications 4 06-29-2009 02:59 PM
