sportsman 500 not getting fuel to carb - Polaris ATV Forum
post #1 of 6 (permalink) Old 06-11-2010, 01:19 PM Thread Starter
racejunkie's Avatar
hello all! having a problem with my 02 sportsman 500ho. heres the story. guy i got it from let it sit outside for 2 years. if i spray
starting fluid into the carb it will fire but when the fuel burns off it dies. before starting i changed all fluids and fuel. i also took off the 2 lines to the carb and when i crank the engine i get no fuel at all out of the lines. any ideas? could it be the distribution block under the left front tire? is there a fuel pump? any help is appreciated.. john
racejunkie is offline
post #2 of 6 (permalink) Old 06-11-2010, 01:54 PM
SCain's Avatar
Is the fuel petcock turned on? On my 2010 there is a fuel on/off switch (petcock) under the cowl below the headlight. I don't know anything about the 02 model, but would think it is a gravity feed to the carb. I would pull the tank and fuel lines and make sure they are clean and clean out the carb since its been sitting for a long time. I would never spray starting fluid into the carb.
Just my .02
SCain is offline
post #3 of 6 (permalink) Old 06-11-2010, 02:01 PM
chopper89's Avatar
Cool
Just my .02
good advice !
2014 850 XP EPS BROWNING EDITION
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP T7 BEADLOCK RIMS
ITP 27 XTR TIRES
RICOCHET A ARM GUARDS
________________________
chopper89 is offline
post #4 of 6 (permalink) Old 06-11-2010, 08:25 PM Thread Starter
racejunkie's Avatar
I did pull off one of the fuel lines to the reserve switch to drain the tank. would it still drain if the petcock was closed and thanks for the help
post #5 of 6 (permalink) Old 06-11-2010, 10:34 PM
Razorback's Avatar
That distribution block is the fuel pump. I'd say it's either the pump, or the needle and seat in the carb is stuck.
Razorback is offline
post #6 of 6 (permalink) Old 06-12-2010, 11:40 PM
odie22's Avatar
also check the fuel filter... any time one sits like that with out starting it up will gum up the carb, i would pull the carb off
odie22 is offline
Scrambler 500 Carb fuel drain chosenoneai ATV Repair and Maintenance 3 07-11-2013 11:28 AM
Fuel leaking from little hose at bottom of carb terkenjegi ATV New Members 10 02-09-2011 02:42 PM
scrambler 500 no fuel to carb defiance666 ATV Repair and Maintenance 1 05-02-2010 10:48 AM
scrambler 500 no fuel to carb defiance666 Polaris Scrambler 0 05-02-2010 08:46 AM
2006 Sportsman leaking (a few drops) of fuel from bottom of Carb GingerRam Polaris Sportsman 4 03-08-2010 10:03 AM
