Old 06-13-2010, 12:44 PM
odie22's Avatar
Member #2429
coolant
what type of coolant do i need for 2000 sportsman 500? i see its green can i just go pick up some green coolant from the parts house? please i need to know.. also witch way does the face need to blow? iam haveing the temp light come on. i put my had in front of the rad and it feels like its pulling air to the motor. i put my hand on the back side were the motor is and i feel air is this right.
-odie22
Old 06-13-2010, 04:56 PM
stanley's Avatar
Member #5422
I use the green from the parts store otherwise you can use the universal coolant that you can add to any make/model. if your machine is getting hot make sure the radiator is clean. remove the side gaurds and screen in front and wash it out good. your fan should suck the air through the radiator towards the motor otherwise while your riding the fan and air flowing from outside would work against eachother
Old 06-14-2010, 02:03 AM
NotQuik's Avatar
Member #4893
Good to know..I thought polaris urged you to use their coolant.
Brian
'04 ATP 500
'04 ATP 330
Old 06-14-2010, 02:37 AM
redneck2725's Avatar
Member #3177
I use Engine Ice, its specially made for ATVs and works great at keeping cooler then the factory coolant. I bought some at my local ATV shop, but most places have it online to order
07 Polaris Predator 500
Yoshimura RS3 slip-on
ITP Holeshot HDs
Powermadd handguards
Shockwears shock covers
PRM radiator scoops
Amsoil oil w/ K&N filter
Engine Ice coolant
ODI Rogue Grips
Old 06-14-2010, 03:29 AM
Parsons Synthetics's Avatar
Member #3476
Send a message via Skype™ to Parsons Synthetics
You can also use AMSOIL Antifreeze Coolant. This is a propylene Glycol fluid that will perform better and last longer.
If I can get you some more information, just let me know.
Take care,
Old 06-14-2010, 08:19 AM
WilliamBos's Avatar
Member #5254
Send a message via Skype™ to WilliamBos
Take care,
Can you add to your existing coolant, or do you need to flush??
Thanks,
Will
2004 GMC 1500CC Z71.
Old 06-15-2010, 03:11 AM
Member #3476
Take care,
Yes you can mix this. It is a concentrate so you have to add water to it.
atv coolant
atv coolent
can i use car coolant on a fourwheeler
can you use car coolent on an atv
can you use regular coolant for atv
coolant for polaris predator
polaris atv coolant
polaris coolant
polaris coolant propylene gycol
polaris coolant type
polaris sportsman coolant green
proper coolant for polaris
what can of coolant the polaris atv used
what coolant does a polaris sportsman 500 use
what kind of antifreeze do i put in a polaris
what kind of antifreeze does a 2004 atp 500 use
what kind of coolant goes in a polaris four wheeler
what king of antifreze do i use in my polaris sportsman
what type antifreeze to put in polaris sportsman
what type of coolant do i use in my polaris four wheeler
coolant odie22 Polaris Sportsman 3 06-13-2010 03:58 PM
Coolant buckfever5 ATV Repair and Maintenance 4 05-08-2010 10:34 AM
coolant spraying eg_runner22 Polaris Predator 7 05-08-2010 09:43 AM
08 800 coolant polarisfamily ATV Repair and Maintenance 0 04-24-2010 03:11 AM
Too much coolant? dodgeram3500 Around The Garage 4 01-20-2010 05:24 PM
