06-13-2010, 07:42 PM
Member #5438
How to change oil on a 2000 Magnum 325???
Hi Everyone,
I've purchased a 2000 Polaris Magnum 325 and I do not have a owners manual...I want to change the oil myself ASAP and would appreciate any guidance!
I am new here and look forward to future communications...
Thanks!!!
06-13-2010, 08:15 PM
06-14-2010, 01:00 PM
Member #5438
Thanks!!!
06-14-2010, 01:05 PM
Member #5438
I plan on getting the new Filter and oil Wednesday...
So if anyone has some tips/hints it would be much appreciated. Looked it over today...I see the filter and the fill hole...mainly what I need to know is;
Where is the drain plug?
06-14-2010, 03:10 PM
Member #2160
the drain plug is on the bottom of the engine. there is a hole in the plastic guard, not sure what size the bolt is, i used a socket and ratchet and it came out no problem. there was some mess from the filter but nothing some cleaner could not take off when the new filter was installed. 0w30 synteic oil should be used.
2000 magnum 325 4x4 Hunter Green
2009 sportsman 500 efi x2 Red
2009 hyundai elantra touring Red
2000 Ford f150 Flare side 5.4l 4X4
06-14-2010, 04:29 PM
Member #5438
Thanks for the Help; Much appreciated!!!
Just to clarify on the drain plug...I do not have access right now, but;
if I am looking at the ATV from the front, my oil fill is on the right side and my oil filter on the left side...is the drain plug directly in between them on the bottom of the engine?
Just want to make sure I don't take the wrong bolt out...
Thanks again!
06-14-2010, 05:22 PM
Member #2160
about 6-8 inchs back from the filter in the middle
06-14-2010, 06:48 PM
Member #5438
Cool! I am sure you've saved me a lot of time and troubles...Thanks again!
06-15-2010, 05:48 PM
Member #5438
Hi,
I am happy to say I got to the oil change today and had no problems getting it done...THANKS again!
BTW, (for anyone reading this thread in the future) I found a 9/16 socket did the trick...
Take care for now, Drew
08-11-2011, 10:31 AM
Member #17379
Fyi
User Manuals available @ Official Global Website For Polaris ATVs, RANGER Vehicles, Snowmobiles, & Victory Motorcycles
They are free to download for registered users.
1. Login
2. Place mouse over "Rider's Guide" Located in 2 places. Top bar and bottom bar on home page.
3. Click "Manuals & Parts"
4. enter fill in fields: "Vehicle Type, Manual Type, Model Year"
( it lists service manuals, but only user manuals worked for me)
You can also find online parts catalog on the same page.
2000 polaris 325 magnum service manual, 2000 polaris magnum 325 oil capacity, 2000 polaris magnum 325 oil change, how to change oil in polaris 325 magnum, how to change oil on polaris magnum 325, oil for polaris magnum 325, polaris 325 magnum oil, polaris 325 magnum oil capacity, polaris 325 magnum oil change, polaris 325 oil capacity, polaris 325 oil change, polaris magnum 325 oil, polaris magnum 325 oil capacity, polaris magnum 325 oil change, you tube polaris 325 magnum how to change oil
