06-29-2009, 04:24 AM
Member #281
No fire
Got the same prob with my 99 500 sportsman,had no spark coil tested bad, replaced coil, now have spark but no fire.goig to check ETC today. Hope we can both get this fixed and back on the trails. will be wathcing this post for any more hints.
06-29-2009, 05:44 AM
Member #618
Let us know what you guys find
06 Predator 500 TLD
07 Sportsman 500 EFI
09 Sportsman 550 XP
06-29-2009, 10:07 AM
Member #767
Like said, start with the ETC switch, there should be a very small gap in the contacts. I have seen 500 motors in the past that with the spark plug out had good spark, but under compression it just wouldn't hold up. I'd try throwing a new plug in it. Have you tested compression? Leakdown? Have you had the carb apart to verify there isn't something blocking a passage? I know it's easy to do, but starter fluid isn't always a good fix. let me know what you find, i'll do some more looking into it.
02-19-2010, 06:06 PM
Member #3266
dont know if you fixed your problem yet or not, but if your interested in used parts im parting out an 03 ,chucked a piston and needed to much to bother rebuilding
03 polaris predator 500 wont start, 03 polaris predator no start, 03 predator 500 wont start after rebuild, 06 polaris predator 500 will not turn over, 2003 polaris 500 predator will not start, 2003 polaris predator 500 problems, 2003 polaris predator 500 turns over but dont start, 2003 polaris predator 500 wants to start but just wont, 2003 polaris predator 500 wont start, my 2003 polaris predator 500 wont start, my 2003 polaris predator wont start, polaris predator 500 spark plug gap, predator 500 no start turning over, spark plug gap polaris predator 500, what type of spark plug do a 2003 polaris predator take
