Old 06-21-2010, 06:21 AM
Sled Solutions's Avatar
Member #4974
Question 2002 Sportsman 500HO not charging?
Have a 02 Polaris Sportsman 500HO that WILL NOT charge the battery. I know the quad doesn't have an alternator like a truck so what charges the battery.
Any help would be greatly appreciated.
Old 06-21-2010, 08:00 AM
proff's Avatar
Member #4309
Polaris ATV's have a stator just like a snowmobile. A common problem on that year machine is the charge wire from the LR( think voltage regulator) corodes and breaks. The LR is located down around the radiator and has several yellow and red wires coming out of it. It usually is a red wire that breaks there. If that isn't it then check your stator
Old 08-18-2010, 08:41 PM
rthrbhntng's Avatar
Member #6622
How do you check the stator? I took off the positive battery cable and the quad still runs but there is no power coming through the + cable. I will check the wires near the radiator too.
Steve
2000 polaris sportsman 500 stator
2002 polaris freedom not charging
2002 polaris sportsman 500 battery not charging
2002 ranger polaris charging problems
2002 sportsman 500 charging system
2003 sportsman 500 not charging
500 ho polaris atv sportsman battey wont charge
how to check alternator on a polaris 500
how to fix a polaris 2002 sportsman 500 that wont charge
oil change 2002 polaris sportsman 500 ho
polaris 06 / 500 ho wont charge
polaris 500 ho charging system
polaris 500 not charging
polaris sportsman 2002 battery charging system
polaris sportsman 500 alternator
polaris sportsman 500 not charging
polaris sportsman not charging
stator for polaris 500 ho
stator location on 2010 sportsman 500 ho
what charges the battery on a 2002 sportsman ho
2002 sportsman 500ho oil leak dattlerb ATV Repair and Maintenance 5 11-13-2010 02:25 PM
01 sportsman 400 not charging turbocav22 ATV Repair and Maintenance 2 05-24-2010 10:23 AM
94 sportsman 400 not charging hairy32 ATV Repair and Maintenance 3 04-08-2010 02:49 PM
2006 500HO X2 not charging linkandcuff Polaris Sportsman 2 01-29-2010 09:12 AM
Oil Change on 2002 Sportman 500HO Bud Man ATV Repair and Maintenance 6 10-19-2009 08:14 PM
