Old 06-26-2010, 11:21 AM
wgungho's Avatar
Member #5613
Hawkeye problems
I bought my Hawkeye new in 2007. At this point it has only 90 hours and less then 800 miles. It is not abused, being used mostly to ride the grandkids around the property. A year ago (at 65 hours) the bike developed a clattering sound behind the cover at my left ankle on the bike. The noise was most noticable in neutral if you revved it and let it wind down. I took it to the dealer, they told me they replaced a bearing. For the next 10 hours things were cool, but the clattering slowly started again, getting louder and louder. I called the dealer and they told me not to worry about. I've stopped riding the bike, because I don't want to seriously damage it. Any suggestions on what "bearing" might be making the noise??? I'm only averaging +/- 8 mph and the bike has never been run at max rpm.
Tom
Old 06-26-2010, 08:14 PM
Old 09-18-2010, 04:14 PM
RadRed44's Avatar
Member #1373
Tom
Anybody else seen this? Mine started making this noise suddenly as well, and the bearing inside the clutch cover seems rough. I will replace the bearing, but it's hard to see how or why this bearing should go bad so prematurely. Doesn't seem like it would have much load on it. What gives? (besides the bearing!)
Old 09-18-2010, 05:56 PM
wgungho's Avatar
Member #5613
I replaced the bearing again with a quality bearing, and I still have a chattering sound when the engine rpm winds down. It's quieter since the new bearing, but still audible, even to my old ears. I'm riding the bike, but wish I could find a mechanic familiar with this model. I'm concerned that I may be damaging the tranny, which is a very expensive repair. Is there another bearing on the same shaft that might also be bad???
Old 09-19-2010, 09:44 AM
RadRed44's Avatar
Member #1373
Well, I replaced the bearing, and the noise mine had been making went away. There is no doubt that the bearing was bad since it felt rough when I spun it on my finger. For my issue, I don't think the tranny would be affected, since I also heard the noise when in neutral. I'm supposing the tranny wouldn't be moving at all in neutral, so unless I start hearing or feeling something else going on, I will assume the tranny is okay. BTW, I got the bearing at Tractor Supply for about $7, though it is Chinese (like the original).
Old 06-06-2011, 04:05 PM
lovedog's Avatar
Member #15752
Gday fellas, greetings from Australia
I have had my 2009 hawkeye since new and it just started the noise you mention. 200 hours still under warranty the dealer mechanic was hoping it was a clutch bearing but no such luck. Its a bearing in the starter clutch and requires the whole back end pulling apart. It was a rattling noise at medium revs but settled to nothing at idle or full noise coming from just around my left ankle. Pain in the arse and i am starting to sniff lemon for the hawkeye as this is the second warranty job the first being a starter bendix clutch.
Old 06-07-2011, 02:57 PM
bondobuster's Avatar
Member #10988
For one of my hawk's the noise was the bearing in the clutch cover. Replaced it and noise went away....
2007 500 H.O. X2 stock with Swamplites (gone)
2 - 2007 Hawkeyes, 10 gr. clutch rollers, 12 in. Razr take-offs w/ stock Maxxis, Aux. oil coolers, 3/16" aluminum skid plates (gone)
2007 Yamaha Grizzly 700 fi eps Limited Edition -stock for now (only one left )
2007 hawkeye polaris clutch noise
2007 polaris hawkeye clutch noise
2007 polaris hawkeye problems
hawkeye polaris loud clutch noise
hawkeye starter clutch
my polaris hawkeye will only run about 16 mph
polaris 300 hawkeye transmission problems
polaris haweye engine noise clutch
polaris hawkeye 300 problems
polaris hawkeye engine noise
polaris hawkeye engine plastics covers
polaris hawkeye hard starting
polaris hawkeye starter clutch bearing
polaris hawkeye starter problem
polaris hawkeye troubleshooting
polaris starter solenoid hawkeye
problem starting polaris hawkeye
replace polaris hawkeye solenoid
Hawkeye Problem fishbone ATV Repair and Maintenance 5 08-09-2010 02:32 PM
Hawkeye 300 itchee1 ATV Repair and Maintenance 1 05-10-2010 09:00 AM
06 hawkeye information crackenzag ATV Repair and Maintenance 3 12-28-2009 08:41 AM
300 Hawkeye or 330 Magnum or? AZDesertRat ATV Purchasing and Price 11 11-21-2009 07:15 PM
300 sportsman/hawkeye canaan canam Polaris Sportsman 5 11-05-2009 06:53 AM
