06-28-2010, 06:57 PM
Member #5672
Has spark, won't start even with starting fluid
I have 95' Trailboss 250. I can't for the life of me get it started. I have a new spark plug with good spark. I've tried starting fluid and can't even get a pop. Even if I'm not getting gas, it should pop with the fluid...
Any ideas? I have to be missing something basic, but what?
06-29-2010, 06:27 AM
Member #5555
Start here....
Check the battery
Check the spark plug
Change out old gas and drain your line
Check your oil and lines
Check and clean the carb, jets, valves and float bowl
Do you hear anything at all? Are you even getting the starter to turn over?
06-29-2010, 07:09 AM
Member #1994
polaris 250
To run, it must have 3 simple ingredients:
1) Spark,
2) fuel, and
3) compression.
You said you have spark.
You said you added fuel (starting fluid)
So, you need to check your compression. It might be time for an overhaul.
06-30-2010, 04:54 PM
Member #5672
Hmmm, I hope not. Just overhauled two years ago...
I'll check compression this weekend.
thx
07-02-2010, 12:04 PM
Member #5568
Check your electrical, even with low compression you should get something when you try to start,maybe you have a short somewhere
07-04-2010, 05:54 AM
Member #3195
My Xplorer 400 had the same issue when I bought it. Ended up being a bad pick-up coil. A chunk of crap from the recoil (elect. starter was bad too) had came loose and smacked the coil cracking the plastic covering and bending the mount. Replaced that and it fired right up.
4 wheeler wont start with starter fluid, articat will not start even with starting fluid, atv wont start even with starter fluid, atv wont start with starting fluid, atv wont start without starting fluid, car won't start even with starting fluid and get spark, engine won't start with starter fluid, engine wont start even with starting fluid, engine wont start with starter fluid, sbc wont start with starting fluid, shoud my atv start will startingfluid, starting fluid for atv, won't start with starting fluid, wont start even with starting fluid, wont start with starting fluid
