Old 07-07-2010, 10:03 AM
chipo's Avatar
Member #5827
magnum 2x4 rebuild ??HELP??
First of all hello everybody. I'm new to polaris i just got a late 90's magnum 425 and it seems to have two problems that are keeping me from enjoying this atv. First i cant get the quad into high or reverse, i suspect that it is the pin that is sheared off that is on the selector inside the transmission. Second it has a very high idle, almost full throttle. I have turned the idle screw and it doesn't do anything and when the bike isn't running i can hear the slide working properly so i think it has something to do with the electronics that are in the throttle. At this point i have the transmission almost off i just need to get the primary clutch, engine, off. I just want to ride this quad, If any one has any help that they can lend me it will be greatly appreciated.
Old 07-07-2010, 11:39 AM
tt425's Avatar
Member #3687
To get the primary clutch off you will need a puller or a 3/4" fine thread bolt 10" long with threads within 4" of head of bolt.
Old 07-07-2010, 12:58 PM
Beenthere's Avatar
Member #2620
First off, this high idle is a carb issue not electrionic. You may want to pull the diaphram off the carb and check it out and, also, your needle valve and seat as well.
I don't know what to tell you about the shifter but good luck!
The Magnums are a fine quad, you'll have lots of fun with it.
95 Magnum 425 4X4
Old 07-07-2010, 06:12 PM
Tags
carburetor issues, gear, transmission
how to rebuild a polaris transmission
how to rebuild polaris trans
polaris 425 magnum clutch
polaris 425 magnum gearbox
polaris 425 magnum transmission
polaris 425 whine
polaris magnum 425 2x4
polaris magnum 425 gearbox
polaris magnum 425 transmission
polaris magnum high idle
polaris magnum transmission
polaris magnum transmission rebuild
polaris transmission rebuild
rebuild polaris atv transmission
rebuild polaris transmission
Magnum 425 carb rebuild jmstett ATV Repair and Maintenance 3 01-30-2012 05:11 PM
Just did a top end rebuild. But... itscody ATV Repair and Maintenance 2 07-04-2010 05:54 AM
Top End Rebuild? itscody ATV Repair and Maintenance 0 06-20-2010 06:43 AM
850 XP engine rebuild SST4530 ATV Performance Modifications 32 06-15-2010 05:11 PM
Rebuild almost done kbhd6180 ATV Repair and Maintenance 6 02-06-2010 04:41 AM
