1995 400l 2*4 carb adjust - Polaris ATV Forum
Old 07-10-2010, 05:04 AM
D-mad's Avatar
Member #5029
Hello everyone
I have a 1995 Polaris 400L and i want to adjust the carb can Someone guide me how to do it
Old 07-10-2010, 06:09 AM
Old 07-16-2010, 03:48 AM
D-mad's Avatar
Member #5029
Anyone???
Old 07-16-2010, 03:48 PM
4getful2's Avatar
Member #1234
my manual doesn't go back that far ,but i will give you what i have for a '98 400.
the pilot screw needs to be 1 1/2 turns out. idle speed 600-700 rpm
the pilot screw setting is just a guideline to get you started,achieve your highest, smoothest idle,then back in 1/4 turn.
the pilot screw and idle speed are both on the right side of the carburator. pilot or air screw you will need a smaller straight blade screwdriver. the idle screw is normally a knob style and can be set with your fingers. both of these adjustments should be done with the engine warmed up and the air cleaner housing installed.
Old 07-17-2010, 01:48 AM
D-mad's Avatar
Member #5029
Thank u
1995 polaris sportsman 400 carburetor
95 400 sportsman carb adjustment
95 polaris sportsman 400 carb adjustment
carb adjustment 01 400 polaris explorer
carb adjustment polaris atv 400 1995
carb setting for polaris xplorer atv 400 l/c 1995
carb settings for 98 polaris 400
how do i adjust the carb on my 1995 polaris atv
how doesa carbarateron a 1995 lpolaris
how to adjusted carburetor on a1995 polaris xplorer
polaris 400 carb settings
polaris xplorer 400 carb settings
Carb settings needed and Carb issues NolenGerke Polaris Trail Blazer 7 01-27-2013 12:51 PM
how do you adjust rear shock? bsmith0505 ATV Brakes & Suspension 2 05-05-2011 04:44 PM
How to adjust idle speed - 01 Sportsman 500 HO sterry31 ATV Repair and Maintenance 3 09-13-2010 01:06 PM
95 400l problems 95-400L ATV Repair and Maintenance 6 05-23-2010 09:08 PM
how to adjust front chain newfiebud ATV Repair and Maintenance 0 05-09-2009 08:24 AM
