Old 07-20-2010, 06:22 PM
cfitz374's Avatar
Member #6057
Changing Fluids
I'm new to this forum. I inherited a 1998 Magnum 4x4. I was told that last summer it was run through a pretty deep creek and probably needs all the fluids changed. I got the fuel, oil and coolant taken care of. What about brake fluid and transmission fluid? Can't seem to find anywhere to drain and/or refill those. Any suggestions would be greatly appreciated. Thanks for your help and suggestions.
Old 07-20-2010, 06:34 PM
racer37l's Avatar
Member #5629
Welcome. The brake fluid can be changed by bleeding all the calipers until you get clean fluid to come out. The trans should have a drain plug somewhere on the bottom. Hope this helps.
Con
Old 07-21-2010, 06:47 AM
2010 polaris 800 ranger fluid changes
2010 polaris ranger brake fluid
2010 polaris ranger fluids
2010 polaris ranger transmission drain
break fluid for polaris ranger
changing brake fluid in polaris ranger
how to change transmission fluid in 2010 ranger xp 800
how to drain brake fluid from polaris atv
polaris 335 sportsman transmission fluid change
polaris ranger brake fluid maintenance
polaris ranger fluid change
polaris ranger xp transmission fluid change
where to check transmission fluid in a polaris ranger800
changing fluids polaris scrambler I need some help jeff3541108 ATV Repair and Maintenance 3 10-28-2011 02:51 PM
Tire Changing nmpolaris ATV Wheels & Tires 4 05-15-2010 04:50 AM
2004 sportsman 700 fluids? edgecrusher1120 ATV Repair and Maintenance 2 04-04-2010 04:29 PM
2007 800x2 fluids finishcarp ATV Repair and Maintenance 6 12-19-2009 12:37 AM
Changing oil krusty32 Polaris Sportsman 1 08-14-2009 03:24 PM
