adjusting shift linkage - Polaris ATV Forum
post #1 of 7 (permalink) Old 07-26-2010, 04:54 PM Thread Starter
big4x4mudder's Avatar
Can some one tell me how to adjust the stift linkages on my 94 sportsman. I had to replace the trans out put shaft bearing now I can't seem to get it set up right. I thought I had it but last time I rode it I had to mess with it a bit to get it into high range and after riding in high it took a few trys to get it back in low range. It works fine from low to reverse if I don't use high range. Is this something I should take it to a shop to set up and if so what will it cost to set up the linkages? I am hoping I don't have to take it in I don't have the cash to spend right now.
Ride it like you stole it!
94 sportsman 400 SOLD
01 sportsman 400
?? 110 Quadzilla
big4x4mudder is offline
post #2 of 7 (permalink) Old 07-28-2010, 11:56 AM Thread Starter
Does anyone know how to adjust this linkage?
01 sportsman 400
?? 110 Quadzilla
post #3 of 7 (permalink) Old 07-28-2010, 01:52 PM
4getful2's Avatar
if both the lil tie rod ends are tight and facing down. put trans. in nuetral and remove the front rod and adjust from there, since you are having trouble getting into high range, you will need to make the rod longer. try to end up with both ends facing down,it has something to with those rods angled too much and binding.
be a good time to take apart your shifter box as well ,and give it a good cleaning. just turn it upside down let it drain and spray some carb. or brake parts cleaner in it. then refill just to the bottom of shifting tubes with your favorite motor oil. happy shifting
4getful2 is offline
post #4 of 7 (permalink) Old 08-02-2010, 05:37 PM Thread Starter
Anyone else know how to adjust this because it worked fine before so I am not going to flip the linkage ends over.
01 sportsman 400
?? 110 Quadzilla
post #5 of 7 (permalink) Old 08-09-2010, 01:41 PM Thread Starter
I know some one on here knows how to adjust this damn thing please help I realy want to go riding soon
01 sportsman 400
?? 110 Quadzilla
post #6 of 7 (permalink) Old 08-09-2010, 01:48 PM
racer37l's Avatar
Not sure, but this might one of the bikes that you have to mash the foot brake to go into high. Hope this helps
Con
racer37l is offline
post #7 of 7 (permalink) Old 08-24-2010, 11:31 AM Thread Starter
HELP ME PLEASE!!!!!! I still have not got this set up right, any one know how to do this? Every time I think I have it set up right (it works in the garage) it messes up when I hit the trails. What is the trick to set this up is it because it is not warmed up when i am setting it up in my garage or what?
01 sportsman 400
?? 110 Quadzilla
Trailboss 250 Shift Linkage Fourtrax ATV Repair and Maintenance 1 10-27-2012 05:23 PM
850 xp adjusting shocks BTH ATV Repair and Maintenance 2 06-22-2010 12:13 PM
Adjusting suspention dodgeram3500 ATV Brakes & Suspension 11 03-17-2010 08:34 AM
broke the shift linkage rod Greg G Polaris Trail Blazer 0 03-07-2010 03:39 PM
shit linkage boot radtad767 ATV Repair and Maintenance 3 11-17-2009 05:08 PM
