Old 07-27-2010, 12:40 PM
dfg307's Avatar
Member #5725
Question swap rear wheels from 4x4 bolt pattern to 4x156
I have a 2001 xplorer 400 4x4 and it has a bolt pattern of 4x4 in the rear and I was wanting to change the bolt pattern to 4x156 is it as easy as swaping hubs. If so are there year and make specific atvs with the same axle and spline count and what not.
Old 07-27-2010, 03:50 PM
The Kid's Avatar
Member #3743
it either an 03 or 04 predator has the 156 hubs but they only came on one year, and i cant remember
The Kid
heel clicker
Warn 2500 puller outter
SS108's
29.5's Laws skinny/fat
rubber down custom intake
homemade exhaust snorkel
rad. relocated up top
chains on front & rear A arms
swaybar removed
Old 07-27-2010, 08:38 PM
Old 07-28-2010, 09:47 AM
josh's Avatar
Member #4417
Probably 03 they changed alot in 04 and kept most of the changes
Old 07-28-2010, 03:53 PM
The Kid's Avatar
Member #3743
i just looked it up and it is 03 he needs
The Kid
heel clicker
SS108's
swaybar removed
Old 07-28-2010, 07:44 PM
dfg307's Avatar
Member #5725
thanks guys ill try the 03 hubs
Old 12-05-2010, 06:22 PM
Xplorer's Avatar
Member #9813
Did this work? I'm looking to do the same thing.
Old 12-05-2010, 06:57 PM
Xplorer's Avatar
Member #9813
Is it as simple as unbolting the old hubs and bolting these on?
Old 12-06-2010, 04:07 AM
The Kid's Avatar
Member #3743
yes
The Kid
heel clicker
SS108's
swaybar removed
Old 01-13-2011, 01:06 AM
95magnum's Avatar
Member #11018
need same
I need to do the same with my 95 magnum, as I cannot find 10 inch tires to fit anymore, and having 4 on 4 bolt pattern on the rear makes it even tougher to find rims too. I currently have 25x12x10 on the rear, can I go to a 25x11x10?
00 polaris xpedition rear hub pattern\
12 rear wheels for xplorer 400
2009 polaris ranger bolt pattern
4x4 bolt pattern
4x4 bolt pattern wheels and tires
4x4 to 4x156 adapter
4x4 to 4x156 adapters
4x4 to 4x156 polaris wheel adapters
4x4 to 4x156 wheel adapter
4x4 to 4x156 wheel adapters
bolt pattern for polaris ranger
bolt pattern polaris ranger
bolt pattern rear polaris scrambler
convert 4x4 bolt pattern to 156
polaris xpedition wheel pattern
what bolt pattern is a polaris ranger
what is the bolt pattern on a polaris ranger
whats size is a 4 x4 bot pattern polaris
wheel adapters 4 x 4 to 4 x156
bolt pattern for a 425 Xpedition 4x4camaro ATV Wheels & Tires 2 04-26-2011 09:48 AM
scrambler rear suspension swap 00Scrambler Polaris Scrambler 1 03-28-2010 04:58 PM
550 XP bolt pattern 70mach1 ATV Wheels & Tires 1 03-13-2010 03:27 PM
Will Polaris wheels pattern match up to a Honda? CINFUL 500 ATV Wheels & Tires 3 01-26-2010 03:59 AM
New rims / Rear wheel swap? lbm33 ATV Wheels & Tires 2 09-05-2009 06:27 AM
