sportsman 500 4x4 won't rev up - Polaris ATV Forum
Old 08-02-2010, 01:31 PM
atvrider824's Avatar
Member #6284
i have a 1998 polaris sportsman 500 4x4 that won't rev up completely...revs up about half throttle and thats it...i've already cleaned carburator checked spark plug gap checked the timing and adjusted the valves any suggestions?
Old 08-02-2010, 01:35 PM
WilliamBos's Avatar
Member #5254
throttle cable adjusted properly?? Just a guess.
Good luck.
Thanks,
Will
2012 Sportsman 400HO - 5,800KM and counting.
25" Traxion Grippers
Warn RT 25, Warn Hawse Fairlead, Synthetic Rope, Glacier III plow, Kolpin Rear Trailbox L&R Mounts.
6" Front LED Lightbar
Polaris HD Front coils
Polaris Hand & Thumb Warmers.
Old 08-02-2010, 04:53 PM
Member #6284
i checked the throttle cable too... still not working right but thanks for the suggestion
Old 08-15-2010, 09:13 AM
fngboy's Avatar
Member #6544
did you find the problem?
did you figure out the problem? My 500 bogs in the mid range.
Old 08-15-2010, 11:42 AM
Member #6284
nope still having problems...the more things i check the more i find thats wrong!
Old 08-15-2010, 02:28 PM
mikeh251's Avatar
Member #6552
does it rev out in park or neutral?
Old 08-25-2010, 11:30 PM
gooey69's Avatar
Member #6634
any luck yet i have trouble w mine also mine rill rev a little like 1/4 1/2 throttle but then acts like the override in reverse
Old 08-26-2010, 05:58 AM
fngboy's Avatar
Member #6544
reverse override
My atv is a 1998 500 sportsman.
mine was the reverse override. Not the switch and not the
LIMITER,RPM,LR-83,HUB GROUND
4060205
It was in the sensor (SWITCH 3233371) in the gear selector.
Trouble shooting. I called a friend. he told me to push the reverse override button. It worked reved up just fine.
I had parted out a 1997 Sportsman 500 so I had all the parts to swap.
I ohmed out the switch from the '97 just to see how it worked. took apart mine and ohmed it out it worked fine. the switch is a normally open so you can actually disconnect I think it was the purple wire from the switch on that board in front and that fixed the problem but you have full throttle in reverse at all times.
I had another RPM limiter installed that and still did the same thing.
Installed the other gear selector and it worked great.
Ronnie's Mail Order for atv parts, atv tires, snowmobile, watercraft and motorcycle featuring an OEM microfiche parts finder.
The other non related things I fixed new. top end 10 over piston. decked the top of the cylinder. Valves ground, decked the head. new top end gasket set. all new rear U joints. voltage regulator. New tie rod end kits. New speedo cable and the little drive link. spark plug, all new fluids. checked all wheel bearing. I am about to bleed down the brakes the left side caliper isn't working as good as the right one. Might have to swap that one. Cleaned my secondary. got a good used primary from a friend. mine the moveable shiv is cracked.
the ATV worked great. 4X4 works great. clutch engagement is really nice. goes about 50. Just got the speedo stuff last night so haven't even rode it with a speedometer yet.
hope this helps.
thanks fngboy
Old 08-26-2010, 06:13 AM
13oliver13's Avatar
Member #6081
Also check that your drive belt isn't slipping.
Old 08-26-2010, 10:00 AM
gooey69's Avatar
Member #6634
mine wont rev up out of gear even. w or w/o the override button pressed
1998 polaris sportsman 500 4x4 wont run at higher rpm
1998 sportsman 500 idels fine but wont rev up
2002 polaris sportsman 500 wont rev up
2008 polaris ranger 500 efi won't rev up
500 sportsman wont rev up
99 polaris sportsman 500 wont rev up
99 polaris sportsman 500 wont rev up after half throttle
polaris 500 sportsman wont rev
polaris 500 won't rev or reach full speed
why would a polaris sportsman atv not tun properly in reverse
