08-05-2010, 02:53 PM
Member #6342
Polaris Predator 500 (No Start)
Just acquired a 2004 Polaris Predator 500. Unit ran great and popped off everytime, however it leaked oil between the crankcase halves.
Tore the machine apart and resealed the case halves. Repalced all gaskets and seals. I followed the service manual to a "T" with regards to torque, timing, valve lash, carb cleaning, etc. I replaced the spark plug, checked compression (120 lbs.), I am getting fuel to the carb and all the lines are free of obstruction. The fuel filters on the petcock are both clean. I tried fresh gas. The choke cable is operational as well as the throttle mechanism. I even did a load test on the battery figuring maybe the plug would spark when there was no load on the battery but not when the engine was building compression. It tested fine. It sits at 12.6 V to start and only drops to 11.7 while cranking. I checked all the wiring and the pulse coil along with the stator and reverse coil. The only thing I have not tried yet is a leak down test.
The thing just will not start anymore. It cranks and cranks and cranks with an ocassional teaser of a pop through the exhaust (gets the hopes up). I don't get it. Very confused. What am I missing?????
I have worked on stuff like this for several years now and have never experienced this yet.
Rule of thumb: Fuel,Spark,and Compression = Running Engine.
08-05-2010, 04:33 PM
Member #6007
uhm, is the coil (that goes to spark plug) on the bike good? or uhm it could be somethin in the electrical sounds like to me the occasional pop is gas build up from not fireing up (its normal). i would take it to a dealer.......im not a pro about it lol
08-05-2010, 04:37 PM
Member #6007
i would try maybe pull starting it the old way by pushin it down a hill or somethin and pop the clutch.
08-16-2010, 09:23 PM
Member #6583
had similar problem. do leak down and double check all your timing. cams might be just off alittle bit. my valves were smashed from being out of time.
08-17-2010, 06:51 PM
Member #6342
Figured out!!!
Sheared Flywheel Key! FIxed and back up and going!
01-19-2011, 04:37 PM
Member #9888
what was it? just curious
01-19-2011, 07:18 PM
Member #8052
um he answer in the post above yours. a sheared flywheel key.
04 predator 500 no compression, 04 predator motor diagram, 06 predator 500 compression, 2002 polaris predator 500 no start, 2004 polaris predator 500 sparkplug and wire, compression on a 2007 polaris predator, polaris predator 500 compression, polaris predator 500 diagram, polaris predator 500 no compression, polaris predator 500 no spark, polaris predator 500 no start, polaris predator 500 not starting, polaris predator 500 pulse coil, polaris predator 500 wiring diagram, polaris predator flywheel key, polaris predator not starting 2004, polaris predator wiring diagram, predator 500 diagram, wire diagrams polaris predator, wiring diagram 2004 predator
