When I put my 07 sportsman efi ho on diagnotics mode and start it the battery reads 11.9....when i give it gas it does not raise any it just stays the same as idling....would that be the stator, voltage regulator, or maybe just need a new battery? Thanks
Does your battery actually go dead? Not being charged? Put a multimeter across the battery terminals and read the DC Voltage. With the engine running you should get something like 14.* volts. Not running 13.2 if it is charged.
Maybe your diagnostics readings are not accurate?
yes it will go dead if i ride it long enough or use my winch. its not charging itself.
113.2K members
