Old 08-17-2010, 02:49 PM
Valerossi's Avatar
Member #6312
08 500HO turn key and nothing?? no power
Its carb model, At first the instrument cluster would come on but it did nothing and I could pull pull start it but the handle bar headlight did not work, After some load testing of battery etc.. nothing comes on Battery tested out fine on my test and at the dealer. Turn the key and I've got nothing. I've checked for broken wires, loose wires etc, what else can I check for??
Old 08-17-2010, 04:54 PM
The Kid's Avatar
Member #3743
bad starter relay
The Kid
heel clicker
Warn 2500 puller outter
SS108's
29.5's Laws skinny/fat
rubber down custom intake
homemade exhaust snorkel
rad. relocated up top
chains on front & rear A arms
swaybar removed
Old 08-17-2010, 04:57 PM
racer37l's Avatar
Member #5629
Have you checked the main fuses(20A)?
Con
Old 08-18-2010, 09:16 AM
Valerossi's Avatar
Member #6312
This may sound stupid but I cant find a fuse anywhere, fuse box fuse panel.. nothing. Ive read on here that people have changed that, but for the life of me I cant find it, I have this thing completely tore apart. So I guess my question is where is this mysterious 20A fuse??
Old 08-18-2010, 12:41 PM
racer37l's Avatar
Member #5629
Open your front storage box and look between the strut mount bolts. There will be a rubber cover that you can pull off, the fuses should be under this cover. The cover itself holds the spare fuses, 2-20A ,1-15A, 1-5or6A. Good luck
Con
Old 08-18-2010, 01:29 PM
Valerossi's Avatar
Member #6312
Nope, no fuse box there. There is nothing mounted on the crossarm between the mounting bolts. Like I said I have this thing stripped of all plastic and I cant find anything that seems to be a fuse. The starter relay showed positive ohms that its good. So i'd hate to start throwing parts at it and get no where. Any suggestions
Old 08-18-2010, 02:15 PM
racer37l's Avatar
Member #5629
Go to Partshark.com. Look at their partsfiche in order to see where the fuses are. Also, they have downloadable pdf manuals.
Con
Old 08-18-2010, 03:48 PM
Valerossi's Avatar
Member #6312
Well I tried the starter solenoid trick of putting a screw driver between the 2 terminals and the quad cranks over, which should mean the solinoid is bad. Just got back from the dealer with a new 50$ solinoid and does not change a damn thing, still no power anywhere, and yes the battery is fine. Any ideas?
Old 08-18-2010, 04:21 PM
racer37l's Avatar
Member #5629
Have you looked to see if you have power to the switch? Trace the wiring from the battery to the switch, then if that is ok, go from there to the starter relay on the control side and elsewhere.
Con
Old 06-11-2011, 02:32 PM
VT500HO's Avatar
Member #15879
2008 500HO Turn on key-no power 8/2010
Found this old thread but can't seem to find how this problem was solved. If I disconnect the positve cable off the battery then reconnect it (with the key in the on position) my gauge cluster displays and the machine can be started. Too wierd. Was it the case of a bad ECM? Are they a recall item?
'no power at key switch on polaris atv
08 polaris sportsman turn key and nothing
2007 polaris sportsman 500 not getting power anywhere
2007 polaris starter selenoid check
2007 sportsman 500 ho no electrical power
how to test 2010 polaris 500 ho starter solenoid
i turn the key and nothing has power
key on still no power atv
no electrical power on my polaris 500 ho
polaris 2007 sportsman 500 ho will do nothing with switch on
polaris 50 no power when key on
polaris 500 atp no power
polaris 500 ho no power at the key
polaris ranger keys
polaris ranger lost power to fuse block
polaris ranger troubleshooting no power
polaris turn key no start
turnkey atv
when i turn the key on of my polaris 500 there is no power
where are the fuses? 2008 500ho
05 500ho atp power problem billnate ATV Repair and Maintenance 12 08-04-2011 08:19 AM
Can i turn them? djtates125 ATV Wheels & Tires 11 03-24-2010 11:35 AM
03 Predator won't turn over no power jef098 Polaris Predator 5 01-25-2010 09:33 AM
02 scrambler 50 won't turn over mdutton ATV Repair and Maintenance 1 10-16-2009 04:54 PM
300 2x4 won't turn over Pakman ATV Repair and Maintenance 0 05-29-2009 08:55 AM
