Idles fine / Only runs when choked - Polaris ATV Forum
post #1 of 2 (permalink) Old 08-22-2010, 06:55 AM Thread Starter
ffmike's Avatar
I have searched and found no answers. I have a 2003 sportsman 700 HO. Hereís my problem: 2 weeks ago I was using my machine to put in some food plots. I was working it real hard all day. Late in the day, it started running bad. It would back fire and hesitate. If I choked it a little bit, it would run fine. It still would idle normal and I didnít have any problems starting it. I brought it home and this is what Iíve done so far. I changed plugs and installed a new fuel filter and new gas. I cleaned the carb (using carb cleaner, I didnít disassemble the carb). I also replaced the carb boot. I starts and idles fine. When I give it gas it almost dies, but if I choke it a little bit, all is fine.
What could be causing the problem? Should I rebuild the carb? Thanks in advance
ffmike is offline
post #2 of 2 (permalink) Old 08-22-2010, 07:26 AM
4getful2's Avatar
it still sounds like you may have some dirt in the carb.yet. try cleaning the pilot jet,normally they are right beside the main jet, just remove it with a screwdriver ,spray some carb.cleaner thru it and some compressed air and all is good.
4getful2 is offline
predator 500 idles but bogs nathangillilan Polaris Predator 10 12-11-2012 08:58 PM
95 xplorer 400 idles bogs and dies icel0rd ATV Repair and Maintenance 8 10-10-2010 06:27 AM
Greetings from Idaho 08 800 quits and only idles idaho800 ATV New Members 6 06-01-2010 11:12 PM
2002 Sportsman 500 H.0. Idles Hot agardino ATV Repair and Maintenance 3 04-01-2010 09:06 AM
key still runs cookieduster Polaris Sportsman 3 06-01-2009 06:31 AM
