Old 09-06-2010, 05:17 PM
Off Road Rebel's Avatar
Member #4462
Exclamation Need some advice, and mabey a part
Ive got an '03 trailboss 330 problem is the batterys not charging. When you test dc voltage at the battery its just continually drawing, even when you ramp up the rpms to what must be WELL past break even, it just draws more droping voltage into the low 11's on a fully charged battery. I pulled the connector off the voltage regulator and found good AC voltage going to it, the voltage increases with rpm. Im worried this means the voltage regualtor is bad???? If somebody knows where to test on the output side (theres about 5-6 wires and i dont have a wiring diagram yet) it would be GREATLY appreciated. there is one jumper wire that goes from the back of the input plug on the regulator that isnt attached to anything, but there seems to be no hookup for it (optioal acc?) but other than that i havent found any bad connections/broken wires etc anywhere else on the bike. Also if it is the regulator are there any aftermarket companys i could get one from? short of the oem partsfisch i cant seem to find these (even on e-bay).
Thanks in advance for any help
Old 09-06-2010, 05:46 PM
i could help you with a VIN# for the machine you are working on, if you PM me
Old 09-07-2010, 11:45 AM
dirttracker's Avatar
Member #6923
If your stator is charging and your battery isn't, you pretty much need a regulator. It's the only thing inbetween that I know of.
Old 09-07-2010, 06:01 PM
Member #4462
I got ahold of a wiring diagram and really took a good look at her today, found a 3into1 connection where the one had corroded almost all the way thru!! i reapired the connection and wala she charges!! feel kinda retarded for missing it before but id rather feel stupid than have to buy a $200 part for nothing! Thanks for the help tho guys
Old 09-08-2010, 12:19 PM
mechanike's Avatar
Member #5749
10/4 on electrical parts are non returnable,,,,,,,,,,,,,,,,,,,,,,
06 sportsman 800 part out j carey Polaris Sportsman 5 10-24-2011 08:31 AM
new part for my 06 sportsmen 500 ho efi johnnyjaws ATV General Discussion 2 09-04-2010 06:52 AM
part swapping lawmanbsi Polaris Outlaw 3 08-09-2010 11:02 AM
part number for 800 eidsonben Polaris Sportsman 1 03-10-2010 09:45 PM
need help finding part n2mudn ATV New Members 9 12-05-2009 08:09 PM
