09-07-2010, 05:32 PM
Member #7086
2005 polaris 500 battery not charging
Here is what I havefound so far
Battery overcharging @ 4000+ RPMS, battery light flashing pushing 17 volts
Have 57/60 from magneto
Have 12 @ the rectifier any ideas?
Also found the post on the top of the starter is loose ( would this cause all the electrical issues?
09-07-2010, 06:11 PM
09-13-2010, 05:40 PM
Member #7245
Hey Jeremy,
I just joined the group today and am having the same problem.
I also have a 2005 Polaris Sportsman 500HO.
I tried 2 new batteries and both died.
I have replaced the ECM (silver box below the head light) because its a recall part.
ECM is the electronic control modual which obviously controls all electrical.
Got it free from the dealer. Thought forsure this would be it but no go.
Battery light came on after running 15 mins with head lights on. Even without
the head lights on my bike will still drain the battery.
If I or you find anything out lets pass it on please.
Cheers and good luck.
10-11-2010, 05:13 PM
Member #7930
Hi guys, I also have a 2005 Polaris Sportsman 500 H.O. and I'm having the exact same charging/electronic issues as you guys, still trying to figure it out...any input/solution will be greatly appreciated! Thanks
08-23-2011, 12:13 PM
Member #7086
update
have any of you found the charging problem?
Still the same issue
battery is good
ECM is good
Output from stator is as per specs
Battery is still overcharging to 17.5 volts
however the battery does not lose it's charge anymore.
SOOOOOOOOO confused
08-30-2011, 09:11 PM
Member #12569
i had the same issues and the dealership thought it was the ECM but it turned out to be the stator. its the peak output that you cant measure thats why everything appears to work with the stator.
08-31-2011, 09:05 AM
Member #17395
Does the 500 use a voltage regulator like the 800's?
05 polaris 500 ho intermitant charging, 07 polaris sportsman 500 not charging, 2005 polaris ranger not charging, 2005 polaris sportsman 500 battery, 2005 polaris sportsman 500 charging problems, 2005 polaris sportsman 500 charging system, 2005 polaris sportsman 500 charging system problems, 2005 polaris sportsman 500 not charging, 2005 sportsman 500 battery, 500 polaris sportsman not charging, 99 polaris 500 battery not charging, battery on polaris ranger not charging, polaris 500 not charging battery, polaris 500 ranger charging system, polaris new battery not charging, polaris ranger 500 not charging, polaris ranger not charging, polaris sportsman 500 charging light, polaris sportsman 500 not charging, sportsman 500 not charging
