Old 07-23-2009, 04:53 AM
cooley1's Avatar
Member #920
05 Predator 500 timing
I was putting new piston rings in yesterday and I lost the timing. I did mark were the timing chain and the cam gears met, but the chain came off the bottom sprocket and i didn't know it. I turned the crank to get the piston back in the jug when i noticed everything. Please help I need to know how to set the timing.
Old 07-23-2009, 05:41 AM
Old 07-24-2009, 12:25 PM
imhuntingcrazy's Avatar
Member #767
hey did you get your machine timed? if not hit me up. i'll see what i can do to help.
Old 10-01-2010, 04:37 PM
polaris predator 500's Avatar
Member #7776
my 2004 predator in making a knocking sound could it be the timing, valves ect?
Old 10-03-2010, 12:29 PM
johnnyjaws's Avatar
Member #6548
knock knock whos there
2006 polaris 500 ho efi E.B.S. sportsmen k&n air filter . Genesis performance module . Hand gards . Back work lights .Front & back bumpers. 2500lbs warn polaris winch. A-arm covers front & back .Front & back rack extenders- Mossy oak soft bags & Rear passanger foot rests .Big wes cargo box .and a 60" polaris plow and a polaris gun side scabberd with 800 miles. Camo water grapics on the hand gards ,speedo mount, front plate,and shifter knob & gas cap- rear storage lid. 3 way head lite mod. Swamp lite 27s on itp ss 212 machined rims 12in. tall clear polaris lock & go wind sheild
05 predator 500 timing
2005 polaris predator 500 timing
2005 polaris predator 500 timing chain
cam timing polaris predator
how to set the timing on a predator 500
how to set timing on polaris predator 500
how to time a polaris predator 500
polaris predator 500 cam timing
polaris predator 500 cam timing diagram
polaris predator 500 timing chain diagram
polaris predator cam timing
predator 500 timing
preditor 500 timing
timing a polaris predator 500
