gas leak - Polaris ATV Forum
Old 09-14-2010, 05:02 PM
shawnboy87's Avatar
Member #7283
gas leak
hey just bought a 2000 500 sportsman and on bottom of carburetor there is a nipple that looks like it suppose to have a hose on it...well this one doesnt and it is leaking gas liek crazy! does it need a hose and where does the hose go? any help thanks guys
Old 09-14-2010, 05:08 PM
scottdeet's Avatar
Member #7044
I believe that nipple is to put a hose on to drain the carb bowl.
Take a look above it and look for a screw, see if it's loose and tighten it.
Edit:Is the nipple sort of where the Red arrow is, if it is look for the screw where I have the Blue arrow.
Take care,
Scott Deeter
Old 09-14-2010, 06:00 PM
shawnboy87's Avatar
Member #7283
hey so i found the screw and tried to tighten it up but it didnt stop the leak...does this mean i need a new screw and new bowl or what? its my dads 4 wheeler so i know nothing about it mine is efi
Old 09-14-2010, 06:13 PM
scottdeet's Avatar
Member #7044
Sorry, I can't answer that, your post caught my eye as I recently did work on a 2005 Trail Boss 330 I bought. In the manual it stated to drain the bowl for long storage, this wasn't ran much at all and it was never drained. I drained it to get the old gas out.
Maybe more experienced will answer this for you. I never took the screw all the way out , just loosened it enough to drain. Possibly it has a gasket of some sort on the end and went bad..........posibly.
Take care,
Scott Deeter
Old 09-15-2010, 03:36 PM
Eastcoastmat's Avatar
Member #7237
Floats in carb are probably stuck
04 predator 500 big bore kit' jet kit full big gun exhaust k&n air box delete kit rev max cdi fox podium shocks all the way around full skid plates and maxis tires
Old 09-15-2010, 04:03 PM
floats and or needle and seat. that carb is going to probably need to be taken apart and clean
Old 09-15-2010, 07:43 PM
shawnboy87's Avatar
Member #7283
thanks guys tons of help will probably take it apart tomorrow...and will let you know how it goes
2007 Sportsman 500 H.O. 4x4 - 26" ITP's and K&N Filter
2000 Sportsman 500 4x4 (Camo) - 25" ITP's and K&N Filter
Old 09-15-2010, 08:25 PM
scottdeet's Avatar
Member #7044
Regarding the nipple that shawnboy87 mentioned and I replied about, is this nipple used for 2 things the over flow & drain? Should there be a hose connected at all times for a possible over flow problem?
Take care,
Scott Deeter
Old 09-16-2010, 03:15 PM
Member #7237
The hose just keeps gas from spilling onto hot engine
1996 polaris atv-gas leak
2003 polaris predator 500 leaking gas from the gas cap
2005 polaris sportsman 500 carb leaking gas
atv gas leak from carburetor
bottom of carborator of 02 polaris sportsman
carberretor leaks out of the bottom on a polaris four wheeler
gas leak 50 polaris 4 wheeler
how to stop gas leak on kawasaki four wheelers
polaris 4 wheeler leaking gas
polaris atv gas leak
polaris carb leaking gas out hose from bottom
polaris four wheeler hose on bottom of carb
Oil Leak yanks2362 ATV Repair and Maintenance 5 02-09-2011 02:48 PM
02 500 oil leak Sampson Polaris Sportsman 1 06-28-2010 06:07 AM
Help! Oil leak 02 700 dtsesthx Polaris Sportsman 2 04-22-2010 01:10 AM
Bad Oil Leak Ozquad Polaris Sportsman 0 01-15-2010 09:23 PM
850 XP Oil Leak Irondog Polaris XP 3 12-14-2009 09:16 PM
