I need help--I'm trying to get to the water pump on a 400 scrambler--what needs to be removed so I can take the water pump apart? I removed the cover for the pull start but that doesn't get me there. HELP
remove the pull starter. remove the flywheel. then remove the counter balance case half.
113.2K members
