04 700 EFI run condition, pops and backfires??? - Polaris ATV Forum
post #1 of 2 (permalink) Old 09-23-2010, 07:14 PM Thread Starter
fasterthebetter's Avatar
Looking for help with this one! A bubby of mine and I are trying to figure out what my ride is doing. It is a 2004 1/2 Sportsman 700 EFI. The quad start and run great but when you are riding about 35 or so at a steady speed it stutters and a light backfiring or popping sound comes from the exhaust. This is not constant, it will be running good and then pop once or twice and then be good for a while and then pop and sputter again.
We have done the blink code check, found a code 52. This is listed as a #2 injector code so we check and cleaned the power and ground connections on injector. Ran the quad and still have the run condition explained above but no code is triggered now.
We loaded it up and took it to the dealer and had then check the computer with their system. There system shows everything is in line, no codes.
We are down to checking the electrical and ignition system out including new plugs.
It has fresh gas in it with injector cleaner. I have ran this in the last two tanks thinking it was a fuel issue. I have also changed the air filter and pre-filter.
Anyone have any thoughts as to what may be causing this??
fasterthebetter is offline
post #2 of 2 (permalink) Old 10-01-2010, 10:13 AM Thread Starter
Got it I think! Cleaned every ground I could find, cleaned the plug that goes into the ECM, installed new spark plugs and cleaned the plug wires up good! Also found mud in the radiator area so cleaned that out real good. So far it runs cooler (I have a cool analog gauge, a must item) and the run condition seems to be gone! Not sure what it was that fixed it but it’s gone! My code 52 seems to be cleared also!!
05 Polaris Sportsman 400 4x4 in showroom condition with lots of extras rgamore ATVs For Sale 4 06-18-2011 05:30 AM
please help...pops out of high range@25mph speedhammer ATV Repair and Maintenance 3 01-06-2011 05:23 PM
2006 showroom condition predator troy lee a must see stb103 ATVs For Sale 0 08-21-2010 11:22 AM
Trailer ATV 12X7 in good condition $1199 OBO utilitytrailer Everything Else 1 08-06-2010 10:56 PM
95 Magnum 425 backfires Spitfire79 ATV Repair and Maintenance 5 04-20-2010 05:04 AM
