08 500 Sportsman Touring H.O EFI Blink code 47 help - Polaris ATV Forum
Old 10-12-2010, 08:26 AM
TheBigZapper's Avatar
Member #8114
Unhappy 08 500 Sportsman Touring H.O EFI Blink code 47 help
Hello.
I have a 2008 Polaris 500 Spotsman Touring H.O EFI.
The Check Engine light is lit after start sometimes and the throttle respons is terrible. it revs up with no problem, but wont idle down. It hovers around 2300 rpm for a couple of seconds, then splutters to a halt. Then it can be a Bi**h to start again, the starter jus clicks and the displa goes black. Turn of the key and turn it back again same thing, try the pullstart and the fuelpump and display comes back on sometimes. Seemes to be better when its cold.
downloaded the Blink codes and got an error 47, wich is IAC Stepper motor:
Open load or IAC Stepper motor: short to ground.
But wath the h... is that? or where is it on the atv? and can I fix it my self?
All help would be apriciated.
Old 10-12-2010, 10:27 AM
Old 10-12-2010, 11:43 AM
countryside_cafe's Avatar
Member #7335
Welcome
Bruce,
I noticed your ATV is very similar to mine. Watch out for the EFI 20amp fuse problem. Mine only has 200 miles on it and rode easy. It does not appear that many owners are aware of the problem. I will locate a shop manual and hopefully electrical schematics to see what that fuse if protecting.
Old 10-16-2010, 08:31 PM
Stealthepooty's Avatar
Member #6542
Blink Code 47
IAC: Short to Ground
IAC = Idle Air Control, part of the EFI system.
The IAC is a non-serviceable item. If it is faulty, it must be replaced.
Test
Pins
1-2, 30 ohms
2-3, 30 ohms
1-3, 60 ohms
4-5, 30 ohms
5-6, 30 ohms
4-6, 60 ohms
All other combinations = OPEN
I can't tell by the wiring diagram on my PC which wire would be ground.
Since the fault says Short to Ground, one of the "All other combinations = OPEN" should be closed.
Such as 1-4, 1-5, 1-6 etc.
Make a table on a piece of paper or spreadsheet and map out all combinations. Then test.
If all the pins in the table above read correctly, and all other combinations read open, the Short to Ground is elsewhere.
Let us know what you find.
_______________________
2010 Polaris 850 XP, Warn XP-30 Winch, KFI Winch Mount, Steel Front & Rear Rack Extenders
My neighbor called the cops because I was playing Radar Love too loud.... they arrested him.
47 failure code polaris 500 sportsman
polaris 500 efi code 47
polaris 500 iac stepper motor
polaris blink code chart
polaris code 47
polaris efi blink code 47
polaris ranger code 47
polaris ranger code47
polaris sportsman 500 efi flash codes
polaris sportsman 500 iac stepper motor
polaris sportsman code 47
what is code 44 and 47 on a 2011 polaris ranger
700 Sportsman 05 Code 41 & 45 Tim ATV Repair and Maintenance 9 02-26-2015 06:04 AM
2008 Sportsman 800...code help crissyissy ATV Repair and Maintenance 5 08-25-2014 07:26 PM
07 sportsman 800 has code 51 wont start boatman Polaris Sportsman 6 10-21-2010 06:31 PM
07 800 sportsman wont start has 51 code boatman ATV Repair and Maintenance 0 10-04-2010 05:53 PM
08 Sportsman 800 Blink Code 42 farmer7 Polaris Sportsman 4 10-29-2009 02:32 PM
