330 Magnum Shift Problems - Polaris ATV Forum
Old 10-13-2010, 09:40 PM
Saltwaterfreak412's Avatar
Member #8185
Hi guys new here been reading for awhile though. My problem is that the four wheeler is in high gear and wont come out, the shifter moves back and forth just fine but the quad will not come out of high gear. Im thinking its possibly something internal, any ideas here guys? Money is tight so all help is appreciated.
Old 10-13-2010, 11:17 PM
Old 10-14-2010, 08:08 AM
96xpress400's Avatar
Member #5551
anybody have any ideas? i have the same problem on my 96 xpress 400L? but mines stuck in low
Old 11-21-2010, 03:22 PM
Member #8185
to the top, does anybody know? its not my four wheeler and i need to fix it asap
Old 11-21-2010, 05:02 PM
tt425's Avatar
Member #3687
The bracket on the top of the transmission is splined. They may be stripped. If not try to adjust the shift linkage rod.
Old 11-21-2010, 05:05 PM
tt425's Avatar
Member #3687
On the linkage you have to get hi/reverse rod and the lo rod set to so they will work together without grinding gears or staying in gear.
2003 polaris 330 magnum transmission grinds in high gear
2004 polaris 330 magnum transmission
2004 polaris 330 magnum transmission problems
grinding noise when in reverse on 2003 polaris magnum 330
how to fix the shifter on polaris 330 magnum
polaris 330 engine issues
polaris 330 gear shift
polaris 330 magnum front shifts in low
polaris 330 magnum trasnmition
polaris 4 wheeler will not come out of gear
polaris magnum 330 trans adjustment
shifting procedure for polaris magnum 330
330 Magnum Shift Problems Saltwaterfreak412 Polaris Magnum 2 11-23-2011 05:01 PM
polaris 330 magnum 4x4 engine problems jstahl ATV Repair and Maintenance 5 01-07-2011 12:43 PM
2003 Polaris Magnum Starting problems hunterbee68 ATV Repair and Maintenance 3 09-22-2010 01:41 PM
2004 Magnum 330 Sportsman Front End Problems beasleys ATV Repair and Maintenance 4 07-30-2010 02:25 PM
Magnum 425 Shifting problems clint1430 ATV Repair and Maintenance 1 05-16-2010 04:54 PM
