2004 Polaris Sportsman 600 wont start - Polaris ATV Forum
post #1 of 11 (permalink) Old 10-25-2010, 06:04 PM Thread Starter
PolarisWes's Avatar
Hello all, new to everything that even involves the word ATV. So please be easy on me. I have a 2004 Polaris Sportsman 600, thing has run great ever since i have had it for about a month or so. All fluids recently changed, I got done riding today jumped off of it and let it idle for a minute(headlights on), and all of a sudden it shut off. Now it will not start, it will not even turn over. You turn the key and absolutely nothing happens. I brought my truck over and attempted to jump it, still nothing you turn the key and it doesn't do anything. Kill switch is NOT engaged. Any ideas? A fuse of some sort? If so where might I look for it?
PolarisWes is offline
post #2 of 11 (permalink) Old 10-25-2010, 08:49 PM
Bruce! is offline
post #3 of 11 (permalink) Old 10-25-2010, 09:29 PM
grub's Avatar
Battery connection? Check for a proper ground. Do you have a multimeter?
2005 Sportsman 800 EFI
grub is offline
post #4 of 11 (permalink) Old 10-26-2010, 04:09 AM Thread Starter
PolarisWes's Avatar
Battery terminals look good, and connected. Any other thoughts?
post #5 of 11 (permalink) Old 10-26-2010, 04:12 AM
mikeirwin88's Avatar
I dont want to sound like a smart ass, but do you have Gas?
Also make sure its on the ON position there will be RES and OFF
mikeirwin88 is offline
post #6 of 11 (permalink) Old 10-26-2010, 04:17 AM
cwlongshot's Avatar
Also key switch. It has three positions. Off run and momentary start.
Double check fuel as suggested. Double check switches and try again.
Cw
2015 RZR 900 Trail BLK. Pearl
Lock N Ride roof
Lock N Ride 1/2 windshield
Lock N Ride rear box
LED lights front, top & rear
LOTS more coming...
cwlongshot is offline
post #7 of 11 (permalink) Old 10-26-2010, 04:21 AM Thread Starter
PolarisWes's Avatar
You don't have to have gas for the ATV to turn over. But yes it does have gas. Literally you turn the key and absolutely nothing happens, when you put the key in the first position the display does not even turn on.
post #8 of 11 (permalink) Old 10-26-2010, 06:41 AM
grub's Avatar
check for ground, you have a break in it somewhere
grub is offline
post #9 of 11 (permalink) Old 10-26-2010, 08:11 AM Thread Starter
PolarisWes's Avatar
The ground look good and connected, could this be a problem with the 20 amp Circuit breaker? Could I have blown a main one?
post #10 of 11 (permalink) Old 10-26-2010, 09:02 AM Thread Starter
PolarisWes's Avatar
Fixed! The Wire harness that connects to the actually key ignition was loose, not disconnected, just loose. Kind of just a random wire that i snugged together happened to fix it. When it was loose me turning the key produce zero result cause it could not relay anything to the starter. Thanks for the help!
1986 Polaris Trail Boss 250 wont start ak_polaris_15 ATV Repair and Maintenance 9 04-16-2012 03:18 PM
98 polaris trailblazer 250 wont start damclaughlin2000 ATV Repair and Maintenance 5 07-24-2010 02:32 PM
2004 sportsman 600 wont start gnv11 ATV Repair and Maintenance 1 06-17-2010 06:01 AM
1999 polaris scrambler wont start ruffryderx88 Polaris Scrambler 17 03-17-2010 09:33 AM
500 polaris wont start. need help please DJ harrison Polaris Sportsman 6 01-31-2010 07:53 PM
