2000 Xplorer bogs and dies - Polaris ATV Forum
Old 10-28-2010, 04:26 PM
Bo185's Avatar
Member #8632
My wifes 2000 xplorer (250) air cooled model is acting wied. It won't start easy and idle. Sometimes it revs up and you can't turn it off. Turn off the key or kill switch and it still runs. It runs fine at times but bogs and misses when at power.
I have rebuilt the carb., but haven't checked compression.
I was searching here and found that it might be the CDI. There are at least two boxes that I think are it under the head light. One might be the fan relay.
Anybody have the correct part number for this unit? Or the right part need to fix this problem?
Help please!
Thanks,
Scott
Old 10-28-2010, 10:53 PM
Old 11-14-2010, 03:30 PM
mt54915's Avatar
Member #9130
ok change the plug adjust your fuel/air mixture check your fuel make sure no water in it or contaminants check air filters check idle speed or it could be a air intake leak
2000 polaris xplorer 250 bogs in reverse
2000 polaris xplorer 250 fan relay
2000 polaris xplorer 250 runs and dies
2000 polaris xplorer 250 stalls when shifted into reverse
2000 polaris xplorer bogging
2000 polaris xplorer bogging down
2000 polaris xplorer dies in reverse
how to fix my polaris xplorer 400 from bogging
polaris xplorer 250 relay
where to find model number for a 2000 polaris xplorer 250
xplorer 250 cooling
95 xplorer 400 idles bogs and dies icel0rd ATV Repair and Maintenance 8 10-10-2010 07:27 AM
300 xplorer now dies when shifted into reverse???? Help jason6586 ATV Repair and Maintenance 2 10-08-2010 01:39 PM
2000 xplorer 400 question laan123 ATV General Discussion 4 08-01-2010 05:25 PM
2000 sportsman 500 dies and fludded dtsesthx Polaris Sportsman 2 10-13-2009 01:20 PM
2000 Xplorer 400 3x4?? reese600 ATV Repair and Maintenance 0 03-17-2009 05:09 PM
