Old 11-12-2010, 12:40 PM
bigbike's Avatar
Member #8768
Sportsman 500 oil change
Hi, my sportsman is due for its oil change now. (06 sportsman 500 EFI)
its at its 50hr mark. so last night i drained out all of the engine oil from the resevoir. but the manual said something about doing something to the oil hose and draining an extra cup of oil from the right side crankcase.
so i looked around and found a little slot with a drain bolt, i un did the bolt and some kind of oil came out of it. i'm not sure if its engine oil or oil from somewhere else. it looked like engine oil.
i added two quarts of pure polaris to it and took it for a drive.
did i do this right? or did i drain something that i wasnt supposed to? thanks please help!
"its good i got a winch"
07 sportsman 500 efi
Old 11-12-2010, 10:00 PM
Razorback's Avatar
Member #4649
Sounds fine to me.
Next time you can avoid pulling the crank case plug by doing this:
After you drain the reservoir, with the ignition off, pull your recoil rope about 10 times. You'll see more oil drain from the reservoir. Repeat this a couple of times. When doing this, your oil pump is sucking up the oil in the crank case and sending it back to the reservoir.
As far as the "priming" step in the instructions, that can usually be skipped. After your oil change is complete and you have added your 2 quarts, your dipstick should show that it's over full. Crank the engine for a few seconds, shut it off, then check the oil again. It should now show that it is at the full mark, or just a little below. If it's still over full, you can try again and if it doesn't work, then you'll have to prime it.
Old 11-13-2010, 05:51 AM
bigbike's Avatar
Member #8768
Originally Posted by Razorback View Post
Sounds fine to me.
thanks for the i like this forum all of the sudden btw happy late veterans day
1998 polaris sportsman 500 oil change
2000 polaris sportsman 500 oil capacity
2000 polaris sportsman 500 oil change
2000 polaris sportsman 500 oil specs
2000 sportsman 500 oil change
2010 polaris sportsman 500 oil change
how much oil do i need to change oil in polaris 500
how much oil for a 2000 sportman 500
how to change oil in 2000 polaris sportsman 500
how to change oil on 2006 polaris sportsman efi 500
how to change oil on a 1998 polaris sportsman 500
how to change the oil in a polaris sportsman 500
04 sportsman 400 oil change questions ngansen Polaris Sportsman 4 11-02-2010 06:38 PM
03 Sportsman 500 HO Fluids Change Hunter11 ATV Repair and Maintenance 9 10-08-2010 04:00 AM
'09 Sportsman XP Tire Change Pinochle767 ATV Wheels & Tires 101 04-01-2010 07:06 PM
08 Sportsman 500 oil change??? kdsberman ATV General Discussion 11 12-20-2009 06:03 AM
Oil & Filter change 500 Sportsman 08 newrider ATV General Discussion 4 10-01-2009 05:50 PM
