1996 400L sportsman top end rebuild - Polaris ATV Forum
post #1 of 2 (permalink) Old 11-20-2010, 09:58 PM Thread Starter
ntwizard's Avatar
Hello all. New to the forum. Have a 96 400L Sportsman and need to replace top head gasket. While having it apart, thought I would pull the head and change rings. Cylinder walls look good but had a very small score on the cylinder wall. I see you can order rings and piston that are standard, .010, .020 , .030 and .040. Are these the different sizes that are the bore size if you had to bore the cyclinder wall. If I have cylinder wall bored, I would have the machinest use one of these bore sizes listed above? Thanks in advance for your help.
ntwizard is offline
post #2 of 2 (permalink) Old 11-21-2010, 06:50 AM
4getful2's Avatar
i let the machine shop pick out the size of the piston, let them do the work. you may want to specify a wiseco brand piston, they seem to hold up better
4getful2 is offline
Sportsman 400 Clutch Rebuild? op2myst Polaris Sportsman 3 10-26-2010 04:31 PM
1996 400L Basketcase fastestdriver01 ATV New Members 1 09-29-2010 06:17 PM
HELP!!! My 1996 Xpress 400L isn't running correctly 96xpress400 ATV Repair and Maintenance 5 09-22-2010 01:41 PM
1994 400l Rebuild littlesweetboy ATV Repair and Maintenance 2 08-15-2010 03:06 PM
94 sportsman no start with carb rebuild ratherbflyn Polaris Sportsman 9 01-24-2010 10:18 AM
