blowing out antifreeze - Page 2 - Polaris ATV Forum
post #11 of 15 (permalink) Old 04-06-2011, 09:28 AM
Hamilton's Avatar
try bleeding the air out of it from the bleeder on the head. It probably has air in the system since you had no other problems before. Check other threads cause theres a lot about this problem on here.
Hamilton is offline
post #12 of 15 (permalink) Old 04-06-2011, 05:26 PM
atvman2010's Avatar
Yeah i agree^^ i dont think it would be anything major since it only started after changing fluids. i mean the headgasket isnt that bad of a job sounds worse then it is but i highly doubt thats you problem mudslinger.
2002 polaris sportsman 700 twin 4x4-rear cargo box
-freshly rebuilt top end
2003 polaris trailboss 330 2x4-freshly rebuilt engine
1987 Yamaha Banshee 350 twin (sold)
1998 Yamaha badger 80 (sold)
1993 arctic cat 550 ext! (snowmobile)
atvman2010 is offline
post #13 of 15 (permalink) Old 04-07-2011, 05:55 AM
Mudd Slinger's Avatar
I'll just keep filling it up until the air works its way out....thanks for the help guys...
Mudd Slinger is offline
post #14 of 15 (permalink) Old 01-14-2014, 05:10 AM
winner1133's Avatar
06 800 efi
Shooting antifreeze out the overflow cap bought this wheeler used have had prob after prob with cooling system so far. I'm thinking rad relocate and thermostat change. I was going to do relocate anyways the radiator gets to full of crap. Thought might make working on cooling system easier any ways. Any thought let me know!?
winner1133 is offline
post #15 of 15 (permalink) Old 01-14-2014, 02:27 PM
Clinebo's Avatar
I see a lot of guys having problems and some of it is this.....the coolant reservoir isn't to be filled all the way. When cold you fill it only to the low level. The high mark is when hot. The coolant needs room to expand when it heats up. If you FILL the tank when it's cold, as soon as it gets hot it's going to purge itself of excess fluid.
When cold my 500 likes to be a bit BELOW the low mark. If I fill it to the low level mark it will still spit some out and return to this level.
2002 Sportsman 500 HO
Warn 25XT + Bumper
25" Grim Reapers
GoldFinger left hand throttle
and other stuff...
Clinebo is offline
850xp oil blowing out vent tube under headlight craigracin15 Polaris XP 65 09-28-2015 06:54 PM
Antifreeze leak xclimber2 ATV Repair and Maintenance 0 11-18-2010 11:39 AM
oiland antifreeze dirt dog Polaris Sportsman 3 10-01-2010 04:35 AM
400 Scrambler keeps blowing head gaskets earthresin Polaris Scrambler 3 04-15-2010 08:30 PM
07 polaris 500 ho drain antifreeze rezrider ATV Repair and Maintenance 0 03-24-2010 12:29 PM
