1997 400L Idle's won't Take any Throttle!!! - Polaris ATV Forum
Old 11-22-2010, 07:54 PM
ddbudd's Avatar
Member #9385
Hi,
I'm New to the Forum hoping for some HELP.
I Just Rebuilt Motor, it will start but will only Idle if you give any Throttle it will bog and backfire and die starts back up and Idle's I have Checked the basics, it is getting spark but seems weak ? will this cause the problem i'm having and if so what should i troubleshoot ?
Thanks dave
Old 11-22-2010, 08:41 PM
mechanike's Avatar
Member #5749
welcome to the forum,make sure you have at least 1/8" play in your thumb throtttle,,,,,adjust 5"up the cable.
Old 11-22-2010, 09:48 PM
Old 11-23-2010, 02:26 AM
4getful2's Avatar
Member #1234
could try taking the carb. off and give it a good cleaning, namely the pilot jet
Old 11-23-2010, 05:20 AM
ddbudd's Avatar
Member #9385
Thanks for the welcome
Found the problem...... I Put a new flywheel on when I did rebuild, It was a 6 magnet , The sport uses a 4 magnet problem solved !!!!!
250cc atv won't take throttle
400 sportman will not take throttle
94 polaris 400l wont idle
atv idles when give throttle it backfires
atv won't take any throttle
polaris 400 atv wont throttle
polaris 400l idle
polaris 500 idles rough and wont take throttle
polaris 500 sportsman 1997 troubleshoot
polaris 500 stumbles
polaris 500 won't take throttle
polaris wont take throttle
Throttle sticking on 94 400L Boostedawd91 Polaris Sportsman 6 06-05-2013 04:14 PM
Thumb Throttle VS Twist Grip Throttle Billster1955 Around The Garage 14 04-02-2013 01:11 PM
Twist throttle vs. thumb throttle? rsmith0801 Polaris Predator 5 03-22-2010 06:11 PM
1997 sportsman 400L Overheating cmb1503 ATV Repair and Maintenance 1 09-27-2009 02:37 PM
1997 Sportsman 400 getting HOT..WHY ? airship Polaris Sportsman 3 09-11-2009 04:04 AM
