01-23-2011, 10:02 AM
Member #9408
Need help with 3 headlight MOD
I recently bought a 2002 Sportsman 700. First the top light doesnt seem to work so guessing its a bad bulb, so trying to figure out how to remove it and see what bulb number it takes to test it first.
Next after I make sure I get it working want to do the 3 light mod. Does anyone have a link on how to do this or a place that sells them because I see it has a relay.
Also does anyone know were i can find a manual for this model Polaris? Im wanting to change the plugs, oil ect..
Thanks!
01-23-2011, 10:42 AM
Member #10101
I recently ordered and received this switch
Polaris Sportsman Three Headlight Mod -
Its quite well made, the installation instructions are clear and simple and Corey(Husky Motorsports) is a great guy to deal with and a member of these forums.
Can't say enough good things about him or the product.
As an aside, I read with great interest the discussion on the diode vs the switch for this mod. In the end, the rationale for using a switch made good sense to me.
Being stupid is not a crime. You are free to go.
Si vis pacem para bellum
'07 Sportsman 500efi, Viper max 3000lb winch, Amsteel cable. Front brush guard, rear rack extender, rear Polaris brush guard, SS312 wheels, 26" Big Horn 2.0 tires, 3 headlight mod, Quadovator temp gauge and fan switch, hand guards, ATV dog seat
01-23-2011, 02:39 PM
Member #9993
I have the same wheeler and the high beam light is 886 bulb and just twists out and unsnaps from wiring harness , very simple.
Here is directions for your 3 light mod that someone posted for me in one of my threads here. It is simple so I would say do it yourself and save some money. It took me about 20 minutes to do. Just go to any parts store and ask for a standard 12V relay they are about $5.
CONVERT TO 3 LIGHT SYSTEM
Converting your Pod light type Polaris Sportsman so that when the high beam selector is on, the bumper lights are also on. (3 headlamps) and when low beam is selected, only the bumper lights are on.
The nicest thing about this mod is that you do not need to cut any wires or drill any holes.
You will need to purchase a standard 12v relay, 4 pieces of 16 gauge wire about 8" long, 4 female crimp on spade connectors(for connection of wires to relay), 4 wire tap connectors.(they are usually blue and you simply insert the wires and squeeze with pliers, then fold back the protective locking cover)
Open the pod and locate the wiring listed below
Relay terminal #30 connect to Polaris green wire (low beams)
Relay terminal #87 connect to Polaris red wire (10 amp protected circuit at the lighter plug)
Relay terminal #86 connect to Polaris wire yellow wire (high beam)
Relay terminal #85 connect to Polaris brown wire (ground)
Use dielectric grease or liquid tape at all electrical connections to prevent corrosion.
The way this functions, is that when you select high beam, you are powering up the relay to give 12v to the low beam circuit from Polaris's 10amp 12v protected circuit. (No fuse needed)
2002 Polaris Sportsman 700 Twin.
3 headlight MOD with relay / Symtec Hand Warmers
Cycle Country Mid Mount Plow
01-23-2011, 02:51 PM
Member #9408
Thanks everyone and TimberGhost because I have been posting in a few differant areas and youve always replied back! Much apperciated!
I think it was cookies? (Thanks!!)
That posted a few manuals and think I found the one for mine. Reading up now to change all the fluids.
01-23-2011, 03:34 PM
Member #9993
You are very welcome. I try to help where I can. Good luck with the new ride.
01-23-2011, 05:12 PM
Member #8052
 if the bulb looks fine, check the ground on the highbeam light. 3 headlight mod is cheap and easy if you can solder a few wires together. i'd recommend heatshink tubing over electrical tape.
01-23-2011, 05:15 PM
Member #9408
Its the bulb it was blown. It looked like it got pretty hot and even melted the plastic. I think i can fix the plastic or hope to make the buld twist back in again. Im hoping just a local auto store will carrry it. After I make sure it works then will do the 3 light mod.
01-23-2011, 05:48 PM
Member #11139
headlight mod
The kit I got has a diode soldered to two wires and covered in heatshrink the total cost was $12 plus the shipping on the rest of my stuff I got.I prefer the diode over a relay just for reliably good luck on your machine.
01-23-2011, 05:52 PM
Member #9408
Thanks, whats the differance between the two just curious?
2007 polaris outlaw 500 headlight bulb, 2009 sportsman 800 headlight mod diagram, 3 headlight mod polaris, 3 headlight mod polaris sportsman, 4 wire 12 volt relay sportsman headlight, atv headlight bulb polaris sportsman connection, cant get polaris trhee light mod to work, polaris 3 headlight mod, polaris 3 headlight mod diagram, polaris 3 headlight mod instructions, polaris 3 way headlight headlamp bulb mod, polaris atv headlight diagram, polaris headlight bypass, polaris headlight mod, polaris headlight mod using a 12v relay, polaris headlight relay mod, polaris sportsman 3 headlight mod, polaris sportsman high beam bypass, polaris xplorer 300 headlight bulb, whats needed for 3 light mod for polarris sportsman
